Old 04-23-2010, 02:35 PM   #1
Stewart Way
Liked 70 Times in 22 Posts
Default A-body Mopar crank centerline
Can someone with a stock A-body Mopar measure and tell me the distance from the crank centerline to the top of the k-member.
Thanks
Stewart Way 2424 SS
Old 04-23-2010, 07:51 PM   #2
Ronnie Hamlin
Liked 29 Times in 8 Posts
Default Re: A-body Mopar crank centerline
Stewart, I can get you a close number as there are a lot of variables. It is 3.7 to 3.8 inches from the crank centerline to the bottom of the front section of the oil pan (before the center sump) Then you will normally see 2 to 3 1/2 inches between the bottom of the pan and top of the k-frame. It depends on the year model as they changed the mounts in 73 and also if the rubber mounts are collapsed. Of course these figures are for a stock "unprepared" car and a 340 engine.
Ronnie Hamlin is offline   Reply With Quote
Old 04-23-2010, 08:14 PM   #3
Moparteacher
try Moparts.com or forabodiesonly.com or bigblockdart.com
Gary Weaver
Moparteacher@yahoo.com
Moparteacher is offline   Reply With Quote
