Old 05-04-2010, 02:28 PM   #21
Lapeeracing
Send a message via AIM to Lapeeracing
Cool Re: Body roll part 2....see!!!
I have been following this thread with some interest. I find it hard to imagine that a sbc would create such a problem.
I think that if you go back to before anything was changed on the car-was there a problem with body roll? If the answer is no then-what has changed? You relocated the leaf springs and rear shocks and reused the existing parts. Now we have a problem-yes? Two shocks are not going to fix it-I doubt that a anti-roll will totally cure it! So,I think we are back to shocks and springs- maybe not in that order- I don't know how you checked those-but I think that is where the problem lies. I would suggest that you talk to the spring mfg and see what they think. I am of the opinion that replacing springs and shocks will take care of your problem. I have done the same on a bbc camaro and did not have that problem.Just my 2 cents-hope that helped with troubleshooting your car-good luck!
Lapeeracing is offline   Reply With Quote
Old 05-05-2010, 11:56 AM   #22
ericsz
Default Re: Body roll part 2....see!!!
Here is a picture of how it left before. Straight as can be.
Eric Bowling
ericsz is offline   Reply With Quote
Old 05-05-2010, 04:06 PM   #23
Mike Pearson
Mike Pearson's Avatar
Liked 1,944 Times in 585 Posts
the problem most likely is not shocks. One time I got to the track and found I had a broken shock mount. I just took both shocks off of the back of the car. The car ran just as good with out the shocks as with. I had monoleafs and ladder bars at the time. Car ran high tens at the time with 10.5 tire. I would check for a twisted axle tube on the rear. There is definately something wrong with the car. I have not had to use a sway bar on my camaro.
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 05-09-2010, 02:14 PM   #24
Ernie Neal
Ernie Neal's Avatar
Liked 328 Times in 80 Posts
Eric, you have a pm
Old 05-09-2010, 05:45 PM   #25
L79racer
L79racer's Avatar
I think you axle tube might be turning in the housing. Check the plug welds.
L79racer is offline   Reply With Quote
Old 05-09-2010, 06:56 PM   #26
Chris "drooze" Wertman
Chris "drooze" Wertman's Avatar
Wow....I dig a hairy ride, but the other pics well, I put a box of diapers and a roll of tp on the dash of the TR7 when it was together, I think I might have actually needed them on that launch. Then again if I can get the chally to launch that hard Ill be in heaven.....
Something changed somewhere. Simple, I dont know enough about chassis setup on a drag car but my dad always said, "Something Changed Somewhere" the trick is to find it, 9 times out of 10 for me its the thing I was sure hadnt. Breakage bent, even on something I just checked and voila......
There is an OLD trick used on bikes (yeah yeah) but frames with low torsional rigidity like the Kaw triples and Suzy trips we used a scribe mounted to a bolt touching a pad (usually a rearset plate) Not as fancy as electronic thingies but it works....maybe one on the rear housing 1 on the chassis ? see where the flex is occuring. Ive seen 2-3 inches of flex on a bike frame of a kaw triple, hence the nickname "Widowmakers" but you were good before, now youre not something changed right ? Grab a coulple nuts and weld on a scribe at a 90 deg angle and bend it so it touches a suface somewhere itll leave a mark behind.....?
Just guessing out loud here.....wow.......that looks like it would be fun to keep straight....
Chris "Drooze" Wertman 3132 (F/SA 2009 Challenger Drag Pak #24 with a best of 10.59)
Chris "drooze" Wertman is offline   Reply With Quote
Old 05-10-2010, 07:32 AM   #27
ericsz
Ernie, I didn't get anything..
Eric Bowling
Old 05-11-2010, 08:24 AM   #28
ericsz
Here is a pic from this past weekend.. Its 5 times better than the first week out but still pretty bad, anti roll should be here this week and got a few more things to check out....
Eric Bowling
Old 05-18-2010, 02:20 PM   #29
ericsz
I just wanted to let everyone know that the anti roll bar fixed and solved my issues!! I went with the DM Products bar and it fixed everythinhg. Thanks for all your help!
Eric Bowling
Old 05-18-2010, 03:50 PM   #30
72Malibu
72Malibu's Avatar
Its amazing what that little bar back there can do as far as stiffening and keeping a frame from twisting.
*** 72 Malibu ***
1.329-3.99-6.28@106.71-9.98@131
best 60ft to date-1.2997
72Malibu is offline   Reply With Quote
