#11 | |
It doesn't seem to work. I'll know for sure tomorrow.
Art Leong 2095 SS |
#12 |
#13 | |
I didn't have the temp gun before but I think the runners stayed cooler longer, till they eventually heat soaked.
Art Leong 2095 SS |
#14 | |
Just make your own heat spacer from a thick sheet of Black Nylon 66. |
#15 |
The spacer is about .300 thick. How thick is the Black Nylon 66?
Art Leong 2095 SS |
#16 | |
http://tridentplastics.thomasnet.com...eet?&forward=1 |
#17 |
Thinking out loud:
Timing ? Reversion? |
#18 | |
Ive got some waterbased ceramic that is a heat dissapation coating, stuff works great. Ive got about a half gallon of the goo left, coating the intake inside and out I can almost guarentee a big heat soak drop......problem is once it does the stuff works the other way around and will hold it in, but it takes a lot longer ? Why kill the water passage ?
Chris "Drooze" Wertman 3132 (F/SA 2009 Challenger Drag Pak #24 with a best of 10.59) |
#19 |
Liked 11 Times in 4 Posts
GOLD my wife is always cold when i am HOT it must be the gold ring
larry dowty 6388 SS |
#20 |
Pulled the motor to check the bearings. didn't mess with the timing belt at all.
Timing light is in the trailer. I'll go get it on Tuesday and double check it but it starts easy and idles great. As far as reversion goes. This is a different cam (much bigger) than last year. I haven't paid attention to the manifold heat this year. Each time out I've been heating the engine, to allow heat soaking. I'm finally going to a track without eyes. So I want to know what I can pick up with a cold intake. Took a leakdown to see if I had some bent intake valves It was 3 to 5 percent (not bad for gasported pistons). This is the motor that I had asked about the compression pressure before It is 300 pounds. I worried myself sick about it. But have just learned to live with it as a quirk with the 4 valve setup.
Art Leong 2095 SS |
