#31 |
Liked 551 Times in 215 Posts
David I can't really tell the story on here.
Low or weak batteries was often a problem in the past.... If you go rounds it happens........... Gear reduction low current draw starters and alternators and good batteries are a must! Stock starters and some batteries are just junk and don't belong in rcaecars......
#32 | |
I would suggest you read a rule book before commenting about my car.
Art Leong 2095 SS |
#33 |
Art I don't know why your feeling like I said something wrong about your car.....all I meant was it's a very different combo and might be effected more than others on some things.
I try to have fun with Drooze......if you think I'm being harsh.....so be it......
#34 | |
Read a rule book
Art Leong 2095 SS |
#35 |
Liked 11 Times in 4 Posts
Art - I think your turbo is broke, your car should go much faster!
Tim Kish 3032 SS/GS |
#36 | |
I typed up a whole long tech explanation last night and the browser froze. Arts car isnt a Turbo, and basically he runs the same system but half, 4 of em , we even have the same crank trigger. What it boils down to is, in our coils, each (the Hemi) there are 2 windings....1 for each plug. So that in itself takes double the juice each cyl fire, (2 plugs per cyl) Now, we didnt listen in the beginning and figured a 12v system would be adequate we heard about half on each side.....so we figured wed try for 12v....well since then the other half has defected to 16v because the issues with juice, starts, rough runs, etc. Now , our 20 amp igniters, which suck over double the juice of the 8amp igniters well, they cure the run problems, but dont help the start issues at all....and can make it worse since you dont see or feel it coming. We had 20+ starts and pit runs, warmups, tech, staging, scales, etc when we were last a nostart. 2 min on a charger would have saved us....but well too many frantic moments and no juice , our generator was down. So live and learn, Id like to go back to the 8 amp igniters because of EM noise, then I could just go 16v like all the other DP's have found is pretty much a neccesity (or two batts)...... Cheers Chris...
Chris "Drooze" Wertman 3132 (F/SA 2009 Challenger Drag Pak #24 with a best of 10.59) |
#37 |
Tim "my" turbo runs fine but I only get 8 or 9 mpg with it.
Art Leong 2095 SS |
#38 |
Thanks to your hard work over the winter I need a bigger Turbo and maybe some Nitrous. I'll call ya later.
#39 |
OH..I get it....It's not a Turbo......Maybe I had to many beers when I typed that reply......
For some reason I thought it was a Stock type engine that came with a Turbo.....My bad....
#40 | |
My stocker with a turbo ran near as fast as my superstocker. Did you think I was that incompetant?
Art Leong 2095 SS |
