Old 06-04-2010, 11:31 AM   #11
Mike Brogniez
Default Re: What air cleaner base is NHRA Legal?
[QUOTE=Wade_Owens;190557]
Originally Posted by John Leichtamer Jr View Post
How much power can a stock type looking base help.
Any dyno test on this subject???????
QUOTE]
2 HP on a 4 jet.......but, even after all the facts and variances, I'm not convinced....
I leave mine off now.....
Wade
Was that dyno result with the hood closed or open.
A gain with the hood open can be lost with the hood closed due to carb to hood clearance.....
Old 06-04-2010, 12:20 PM   #12
Larry Fulton
Larry Fulton's Avatar
Originally Posted by bruce noland View Post
james,
at least 10 racers had them on at indy in 2005. Bruce told me mine was fine and that he had no problem with it. I ran that same base for 3 more years and went through tear down at indy in 2008 with the very same crew that is now trying to outlaw its use. This isn't a tech issue. It is a nhra issue. Glad i'm out of this mess.
All of this Air Cleaner Base BS... is just more confirmation of just how F***ed up things are... from Div. to Div. and from HQ in Glendora!
NHRA has let the S*** get so far outta control, that now, none of them even know what is correct or "Whats Accepted".
Larry Fulton
Larry Fulton is offline   Reply With Quote
Old 06-04-2010, 12:47 PM   #13
Bobby DiDomenico
Liked 104 Times in 53 Posts
Originally Posted by Lew Silverman View Post
We've been told that an OEM or OEM-style air cleaner can be used, which means a K&N base is OK, but not the stub-stack. I'll venture a guess that a custom molded base doesn't fit some folks interpretation of what an "OEM" air cleaner should look like. There are a number of threads on air cleaners in the tech section that explain it much better than I can.
Lew
Lew,
Ran the stock A/C assembly because of a hoop scoop, but always thought that OEM would mean what came on the car with that silly little tube with the exhaust stove top warmer snorkel assembly on most cars. I know nearly everyone runs either the flat open base or flat base with open element style. One of my guests yesterday was shocked upon seeing the 6" (?) dia. pipe and element on a new Cobra Jet.
Can anyone really runs 10's thru a 4 square inch hole? Guessing whatever they allow is ok as long as it gets "factored" into the equation...
Old 06-04-2010, 01:33 PM   #14
Chris "drooze" Wertman
Chris "drooze" Wertman's Avatar
Originally Posted by James Perrone View Post
Thank guys
I understand about stock type .
Micheal was told a K&N or moroso or stock style.
I here you it had to a crybaby..But Rules Is Rules
WJ... Drools may run this site but Tech picks on everyone evenly..
Wonder way the geunius is GIVING UP...
It saddens me to se continued misreading of my posts....
Giving up ? Were going to add 2 cars to the game.....In addition to replacing the DP if it sells, if not well still add the other 2, only 1 will track this year if the DP dosent sell however.
Do you really believe the "inventive" interpretation of things you "think" you read ? It explicitly said I wasnt giving up, rather going in deeper........Do you want people to actually believe what you say when you outright put blatant lies to this board ? Do you really think people are that gulliable ?
James, my, you cant even leave me out of your own posts......
With so much bitterness, is it something personal , did I date your daughter, or niece or something ? If so I am sorry, they were forgettable and a I apologize.
James, Incorrect about something ? From the air you purport you are without error, hence this must be the NHRA's fault right ? No culpability for yourself ?
James since you offered me assistance with the scales and slip , I will offer in kind, we will have remedial reading lessons by Mandie at the Trailer at Norwalk, and an Advanced class on how to read a rulebook held later in the day, there is no charge......
Just doing what I can to offer the same type of help you offer
Chris "Drooze" Wertman 3132 (F/SA 2009 Challenger Drag Pak #24 with a best of 10.59)
Chris "drooze" Wertman is offline   Reply With Quote
Old 06-04-2010, 01:43 PM   #15
Originally Posted by Bobby DiDomenico View Post
Lew,
Why run an air cleaner ? Im serious ? If your air cleaner and snorkel are creating a retriction, the rules say Air Cleaner Optional .... Why run one at all ? Temperature ? I mean ? They are race cars ,,,,, Am I missing something here ?
And I ask that in all honesty......what am I missing ?
Old 06-04-2010, 01:56 PM   #16
Wade_Owens
Wade_Owens's Avatar
Liked 3 Times in 1 Post
[QUOTE=Mike Brogniez;190572]
Lost 4hp with the hood down........Mine was engine dyno, my friend that lost the 4hp was on a wheel driven...
Old 06-04-2010, 02:19 PM   #17
Bobby DiDomenico
That would be are you allowed to run a non stock base that improves air flow, not about running the stock air cleaner.
Old 06-04-2010, 02:26 PM   #18
novassdude
Liked 136 Times in 49 Posts
Are you running just the base? Or the base and air cleaner?
novassdude is offline   Reply With Quote
Old 06-04-2010, 02:31 PM   #19
Gotcha, I knew I had to be missing something.
I was actually wondering if many or any run elements....I hadnt seen many....I have seen a few....
Old 06-04-2010, 03:14 PM   #20
Tim Kish
Liked 11 Times in 4 Posts
Many run air cleaner elements in bracket mode and remove it for heads up runs.
Tim Kish
3032 SS/GS
Tim Kish is offline   Reply With Quote
