Liked 4,388 Times in 504 Posts
I am using Phoenix ph379 13/31 right now but I think they are way too big for my application.
What do you guys recommend for a stick car? Something with a stiff sidewall and medium compound? Or do you know a knowledgeable source for me to contact? Thanks. |
I think the M/T 9x29.5S would work just fine for your application. I still had them on my AMX with Cal-Track parts with the 390 Superstock engine and went 10.0's with 1.38 60' and a 7200-7800 RPM launch. A 289 would be a piece of cake!
But then again I felt the need to re-work my car and for some reason got talked into a pair of 14.5 x 31.5 GY's. Sounds like way to much tire as well.
Jeff Lee 7494 D/S '70 AMX |
I don't run tubes with the 9X 29.5S M/Ts. Since the tubes came out, no more flat tires
Cam Chowen 6067 1994 Camaro C/S |
Liked 165 Times in 54 Posts
I put a set of MT stiff sidewalls on my daily driven mustang and picked up .06 in my 60fts. Its a stickshift but i run a 28x10.5in slick. 10.70s N/A
Stephen Johnson #2162 Horace Johnson #2167 SS/D 427 Ford Fairlane NHRA-IHRA |
No tubes.
I am not running tubes in the Phoenix right now.
Liked 130 Times in 20 Posts
Mickey thompson 3072 Bias ply no tubes. You will be very happy.
Brad Zaskowski 3697 STK, SS |
Brad,
What is the 3072 tire size and compound? Keith
Keith A/S 2990/Terri A/SA 2991 "Imagine what you'd attempt, if you knew you could not fail!" |
Liked 115 Times in 5 Posts
I swear by the M/Ts 9x29.5 ST on my Stocker. No tube and they last 75 runs.
Evan
Evan Smith 1798 STK |
3072 13x31 M5 compound 98 rollout. We run this on both of our SS cars.
The 9x29.5 ST is what we run on our stocker and it works great too.
