Hey guys
I am building a 76 camaro, K/SA 350cid,turbo 350 275 1st,10 bolt with 4.56 gears,stock springs,should weigh 3775, what should my pinion angle be, Thank You for your help Lonnie |
Liked 5 Times in 3 Posts
-2 degrees( that's a ballpark figure). you running "slapper bars" or Cal-Tracks? also what size tire you going to run?
If you're using regular "slapper" bars you're going to want more than 2 degrees with that much gear and that much weight. I'd try about 6 degrees! You can better control your angle with a "cal-trac".
Tire is a 30 tall,cal tracs some day .
Thank You for your help |
Liked 1,886 Times in 423 Posts
Don't wait, get the CalTracs ASAP. Buy the springs, too. Fighting a car that doesn't work well is far worse than fighting a car that is a little down on power.
Alan Roehrich 212A G/S |
