Old 06-15-2010, 12:29 PM   #1
John Lang
Liked 6 Times in 2 Posts
Cool One more time, Radial vs Bias Ply
As it says above what kind of differance, between Radials, and Bias Ply, all other things being equal ! Same gear, same dia, same weight ,etc ! E.T.,MPH, 60 ft , tire life, etc ? Just a differance of opinion ! Thanks .........John...PP.SS It's a stocker !
John Lang 365 STK, SS
John Lang is offline   Reply With Quote
Old 06-15-2010, 08:46 PM   #2
72Malibu
72Malibu's Avatar
Default Re: One more time, Radial vs Bias Ply
A radial is going to be worth about a tenth, I've never had a bias tire come close to the performance of a radial slick. I get about 100 passes up to 120 passes on a pair of 30x9 Hoosier radial slicks.
*** 72 Malibu ***
1.329-3.99-6.28@106.71-9.98@131
best 60ft to date-1.2997
72Malibu is offline   Reply With Quote
Old 06-17-2010, 05:57 AM   #3
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
Do you swap your tires from side to side? If so, do you have a set schedule for swapping?
I run the (94") 30X9 Hoosier radial slicks, and can only average 75-90 passes before my 60's start going away. I do swap at about every 25 passes....
Old 06-17-2010, 07:28 AM   #4
Michael Beard
Michael Beard's Avatar
Liked 13 Times in 9 Posts
30" Radial is .12-.13 faster in the 1/4 mile for a similar sized tire, and still a good bit faster than even a 28" bias. I've never rotated mine. Typically run 18psi. 112-115 runs on the M/T 3066R (30x9 radial), been 1.41 60' on cords. 60's are dead-on until 110 runs, then they might blow them off completely, then come right back for a couple runs. I can only remember about 3 runs out of 1,200+ where the tire slipped "just a little". That's why I bracket race on them full time. They print timeslips.
Old 06-17-2010, 12:36 PM   #5
Alan Warman
I am getting ready to switch over to radials. So which rim width is the best, 8" 9" or 10".
Alan Warman
STK 4107
Alan Warman is offline   Reply With Quote
Old 06-17-2010, 05:23 PM   #6
j gardiner
Liked 55 Times in 29 Posts
I was told by the Hoosier tire rep not to switch the tires from side to side because you will lose tire life. I just changed mine after 130 runs and they still had a good bit of dot left in them, and I never switch mine.
j gardiner is offline   Reply With Quote
Old 06-17-2010, 05:33 PM   #7
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: One more time, Radial vs Bias Ply
I'm gonna have to sit down and count the runs one day, but I swap my Hoosier lightweight radials from side-to-side after every race weekend! I've been happy with the wear and traction. When I didn't swap the slicks often many years ago, it seemed that one side wore a little faster.
Old 06-17-2010, 07:49 PM   #8
67camaroracer
67camaroracer's Avatar
Have you ever tested ET street radials vs bias ply? Would the tenth gained for having radials pertain to the ET Streets as well?
Not trying to hijack but haven't seen this question asked just yet.
David Vum
67camaroracer is offline   Reply With Quote
