what kind of transmission do the new challengers use ? i heard jeg say that the 1~ 2 shift was done automatic and that all he had to do was shift into high also does ford or g m make a transmission that does that.
#2 | |
We use a 904, most others use a Protrans 904 guts in a 727 case. The valve body WE use is a Turbo Action E-Shift. You can set it up to do 1-2 or in our case 1-2-3 as well as Burnout mode and Pitroad mode. If I was a betting man (which I am) I would guess Jeg is using a protrans, and an electric 1-2 shift. Most Protrans DP's are
Chris "Drooze" Wertman 3132 (F/SA 2009 Challenger Drag Pak #24 with a best of 10.59) |
I'm the type of guy that always thinks out of the box. I actually thought about using the stock 722.6 automatic transmission at one point. 3.59 1st gear and computer controlled upshifting. I already have the PSC standalone for it where we could put the car in D for "dumb" and let her buck. No tach, no shift light, however we finally decided to throw a stick in the car and have some fun.
Jerry Williams NSS/A, E/S, PRO E.T. And the "Grandaddy" of Gen III Hemi Performance...The fire inside me still burn's. |
Liked 325 Times in 50 Posts
We used the Pro Trans 727 small block case as the pump is larger and so is the input shaft. The rest is 904. Had a learning curve to teach the old driver not to shift the damn thing as it does the 1/2 by itself and all you gotta do is shift the 2/3. I did a lot of 1/3 shifts. Course, I'm older than dirt and a little slower.
Jeff Teuton 4022 STK |
#5 | |
Liked 502 Times in 130 Posts
Eric Merryfield 1883 STK |
Protrans 727/904 in mine, when it gets here.
Eric, I have a Browell can (new), 2 McCloud Clutch assemblies (new) and 3 borrowed Jerico's and a guy named Helms or something like that who on occasion shifts a stock car. Who knows what the next drag pak might bring. Leftover stuff from the Top Stock days. Lotta leftover stuff from the Top Stock days. Congratulations on your recent debut. Goes a little fast huh? I really cannot get used to the doors closing and not rattling like previous cars I have had. I had to learn not to slam them.
#8 | |
As you have pointed out numerous times in the past, the playing field isn't always level. My dakota once upon a time was the #1 qualifier @ Indy when Six ran it, now many years later, it isn't even in the ballpark. The fords will soon be running amock over all the classes. Even the lower HP DP's. Re Denver: I don't know if I could get the wife to do a 2,000 mile trek out to denver, maybe if someone in D-1 is going with room to spare in a stacker, then I could take care of the dukes of hazard move for you in your trailer. Enjoy it all, it doesn't last long enough. Eric
#9 | |
Liked 10,837 Times in 2,252 Posts
Eric, What year was Raymond King's truck #1 qualifier at Indy?
