Old 06-24-2010, 10:54 AM   #11
FED 387
Liked 335 Times in 182 Posts
Default Re: Sleeveing a block
we have used Darton sleeves with success in many applications---Comp 387
Old 06-24-2010, 03:55 PM   #12
Todd Bailey
Liked 33 Times in 17 Posts
Had my engine builder tell me many years ago that if I brought him an engine run on rubber mounts and an engine run with steel mounts, he could tell which was which from looking at the mains. Rubber mounts and tie it down!!
Todd Bailey is offline   Reply With Quote
Old 06-25-2010, 12:36 AM   #13
Alan Warman
Jerry
Do you remember were you found the sleeves. Every body I talked to, keeps putting that custom word in front of the part number. Mellings has a sleeve but I do not think the O D is big enough. The bore size of the 350 is 4.057 and the sleeve is 4.062. So far LA Sleeves has the best price. So from all the info from every body. Between chassis flex and solid mounts is what killed the block.
Alan Warman
STK 4107
Alan Warman is offline   Reply With Quote
Old 06-25-2010, 08:05 PM   #14
JRyan
Liked 112 Times in 31 Posts
Alan,
LA Sleeves is where I got mine. Not cheap, but they don't require any super trick cylinder wall finishes to get them to seal. The non-windowed block with these sleeves is plenty strong even for the 3550 lb. Superstocker with bumper draggin' wheelies, so you shouldn't have a problem as long as your chassis doesn't flex. Good luck!
Jerry
Old 06-26-2010, 01:31 PM   #15
Daran Summerton
Daran Summerton's Avatar
Liked 66 Times in 37 Posts
Is this the roller cam motor? Either way 307's don't need anything done to them. You have a problem. The old wagon (roller motor) is still together after 8 years and can still set the record at will. May just start fresh with a known good virgin core motor. If your not running the roller cam motor I reccommend you do at this point. Call with any questions Daran
Daran Summerton is offline   Reply With Quote
Old 06-27-2010, 11:43 AM   #16
Run to Rund
Liked 55 Times in 28 Posts
The 403 guys on ROP generally run a main cap girdle to help hold the windowed main block together. J&S and others have girdles. I suspect the DX block is overkill and very heavy, but a 350 block sleeved might be best. Of course, a block with .921 lifters would help with a radical profile cam vs. the .842" lifter blocks.
Old 06-27-2010, 12:29 PM   #17
Jeff Lee
Jeff Lee's Avatar
But lifter bores must be for the make/year claimed.
Jeff Lee 7494 D/S '70 AMX
Old 06-27-2010, 02:20 PM   #18
SSDiv6
Jeff is correct, you have to run the OEM lifter diameter. You cannot modify the oil pan externally in Stock Eliminator, therefore, you cannot run the commercial girdle available for Olds engines. The best bet is like Jerry and other have done; sleeve an early high nickle Oldsmobile block or find a NASCAR block with the small mains and small bore.
Old 06-27-2010, 06:05 PM   #19
JRyan
Speaking of chassis flex; If Daran's flexible flyer wasn't having block problems with the way that thing twisted, nobody should. We haven't had any problems with the 307 blocks in any stockers either, but it might be that Alan has a problem peculiar to his car, or just bad luck. In any case, I know the sleeved 350 blocks work very well for us.
Jerry
Old 06-27-2010, 10:00 PM   #20
Alan Warman
Well if I did not have bad luck, I would not have any luck at all. I don't think its chassis flex but I could be wrong. Here is a couple of things I noticed when tearing it down. The solid mount's are touching the frame. And the balancer I use is the stock solid cast hub. No rubber at all
Alan Warman
STK 4107
