I had my PG "freshened" and now have a problem with park. On an 10% incline and when tightening the tie downs it will not hold. I now use an chain and binder as "back up" on the trailer up front and back. Without the back up the car acts like I am towing it in neutral. Money is tight so I can not afford a new trans and the freshener says no warranty on racing trans. I left his name out on purpose (in Conn.).
![]() Phil Daly aka Chevellewagon. |
Find yourself a reputable shop and describe the problem, they'll probably help you. It sounds like a linkage problem, but given someone who has so little pride as to not offer ANY warranty has been in it, I can't say for sure. Just for the heck of it, check your linkage adjustment carefully.
Alan Roehrich 212A G/S |
Thanks for the help. I'll check the cable set up.
PS It worked fine before. Phil |
Liked 362 Times in 105 Posts
When setting the linkage use high gear on the setup then check park before placing the linkage back on. Put the trans lever in park then put the shifter in park and see if the two line up and go together easily. If not you may be using the wrong hole in the shifter linkage on the trans. Most of the shift levers on the trans have several holes so make sure the setup is in the correct hole for the shifter you use. This is the most common problem.
If the issue is still the same and will hot hold park I think the parking paw spring loaded engage lever inside the trans is not placed correctly. This can easily be fixed by pulling the pan only and working on it in the car. Try and see. If the trans works other than park the linkage inside is probably the issue if the shifter linkage is correct. Remember to use high gear to check the setup then to Park. Good Luck and if you still have the issue I can walk you through the fix on the internals on the phone when you are under the car looking at it if needed. |
Liked 886 Times in 238 Posts
Like 63Vette said, check the linkage adjustment first. ......This also can becaused by a crack in the "rooster comb" where it clamps on to the shift shaft. ........This is becoming far more common now days ,as the clamping bolt has been tightened ,[or overtightened ] many times on most PG's...........The trans will shift all the detents correctly ,but the extra force required to overcome the spring pressure of the park plunger will twist the rooster comb on the shaft.....Easy repair ,even for someone not familiar with automatics, only pan and shaft removal required. .............Tom
#6 | |
![]() Chevellewagon |
#7 | |
That's why I like this forum as poeple will to give advice and not make the person look or feel dumb. ![]() Now if I can win powerball maybe the car can be competetive in K/SA..........LOL!! |
Liked 92 Times in 29 Posts
Your problem might be the fact of tieing down your car up against the park pawl itself. That puts a lot of stress on the park pawl and the case. I put the straps on loose then put in nuetral then tighten straps down tight.
#9 | |
