Liked 335 Times in 182 Posts
If a Holley 1050 carb is/has been calibrated for use with alcohol and ya want to convert it over to be used with GAS---what needs to be changed other than jets??? or vice versa gas to alcohol---- anybody know for sure no guesses here please--thanx Comp 387
Given what it takes to convert a gas carb to alcohol, it's a lot more than jets, and I'm not sure you can reverse the process, I've never tried. There are all sorts of restrictions you drill out to go to alcohol, you'd have to close them back up. It'd take a 1/2 hour or more to detail it here.
Alan Roehrich 212A G/S |
They are two different beasts: for starters, metering blocks are different and need to be changed. Inlet valves and bowl are different. Bleed orifices are also different.
Thanx for the replies---did not want to get totally involved in going that route either---had a chance to pick a few basket cases cheap just do not want the hassle of trying to make one work--thanx Comp 387
I have a 1050 Pro System Alochol Dominator I'll sell you. It has about 70 pass, most of which were 1/8 mile. Looks and works like new. New ones go for $1,100.00 let this one go for $750.00
Jim Thurston 616-399-2069 r-thurston@sbcglobal.net |
Boosters and booster pins, and both metering blocks. How cheap?
