#11 |
Liked 798 Times in 212 Posts
Rich
Maxxis does have a E rated tire, so that's probably what i'm looking to buy. Thx for the help. Pete |
#12 |
Liked 100 Times in 45 Posts
Someone posted about taking heat gun readings on a trip.What temp range is of concern when taking the readings?Just facts,not speculation.Thanks.
Former NHRA #1945 Former IHRA #1945 T/SA |
#13 |
Liked 18 Times in 8 Posts
I also use a temp gun to regulate my brake adjustment. It only takes a minuite, when you stop to fuel up. you can shoot the tire and the hub quickly as you walk buy while fueling. This will identify any potential problem that will put you on the side of the road, and potentially cost a lot of $$$$. I will get under and adjust and/or investigate a reading in excess of 20% (hotter or colder) of the other wheels (6 in my case). Most of the time I'll be within 10% on my normal adjustment maintaince program. Also very important and potentially costly, check the bearings lube and replace as needed. I have the E-Z lube axles but don't use that feature, because of the chance of pushing the grease past the seal and into the brake shoe area. You know what happens next. I try to take the stuff apart once a year and replace as needed and hand pack the bearings.
Wade Mahaffey |
#14 |
Thanks Wade.
#15 |
Liked 544 Times in 213 Posts
My Classic trailer has Nev-r-lube axle bearings.......I never heard of them before I bought the trailer. They are sealed bearing cartridges. Nothing to pack or adjust. I replaced all 4 when I did brakes. One set of shoes had NO brake lining material on either shoe....none! Was having issues stopping and after a little inspection I saw why. I replaced the bearing cartridges just so I would feel better.......One snap ring and they press in and out of the drums hub. All your supposed to do is inspect them for any obvious grease leaks and check the play by rocking the wheel with it off the ground......They are good so far and I kept the old ones for spares......they were also good...
High end travel trailers, like airstreams, have been using these bearings.
#16 |
Liked 881 Times in 452 Posts
Who makes who:
PRIVATE BRAND TIRE SELLER TIRE MAKER Advance China Mfrgs. All China Mfrgs. Aerolon Lucas Automotive Denman (bias antique, classic automobile) Aero Track Greenball Corp. Cheng-Shin (ATV) Akuret Del-Nat Tire Corp. Yokohama (P, HP) Alta Racer Greenball Corp. Cheng-Shin (Taiwan) (bias racing) American Radial Amer. Car Care Michelin Apache Tire Factory Continental General Tire Apple I Frank's Tire Arizonian Discount Tire Kelly (P, LTR) Armour China Mfrgs. All. Jiangsu Tyre (IND) Astra Tire Factory Continental General Tire Astro Tire Group Int. Govind Rubber Ltd. (GRL) (india) Danubiana (Roumania) [farm] Madras Elastomeres (india) [solid IND] Chaoyang (China) [pneumatic IND] Roadstone (Thailand) [OTR, IND] Dong-Ah (Korea) [tubes, flaps] Atlas TeamTBA Kelly Betco Coker Tire Specialty tires, Denman Big O TBC/Big O Kelly Bilt-Mor Rott-Keller Co. Off-shore Brigadier Reynolds Tire Conti General Cambridge Dunlap & Kyle Various off-shore (MTR) Candy Classic Fairmount Tire Dunlop (P-bias wide whitewall for classic cars) Capitol Dynastar Int. Coker Classic Coker Tire Specialty tires, Denman Commander Coker Tire Specialty tires, Denman CO-OP Triton Tire Bridgestone/Firestone, Kelly, Dunlop Cordovan TBC Corp. Cooper, Kelly Cornell Pep Boys Bridgestone/Firestone Cosmo Tire Group Int. Chaoyang Country Squire Triton Tire Kelly, Continental General Custom Classic Lucas Automotive Bridgestone/Firestone, Denman (bias for classic cars 1930s-'50s) Danzig Foreign Tire Sales Various (off-shore) Delta Del-Nat Tire Corp. Yokohama (P, HP, LTR), Cooper (P, HP, LTR), China Manufacturers Alliance (MTR, MTB, MTLP), Cheng Shin (P, HP, LTR, IND, lawn/garden, ATV, boat trailer), Toyo (P), Denman (LTB, F/I-B), Alpha (LTB, MTB, IND, Alliance (F/I-R, F/I-B), Ceat (IND), Cupples (tubes) Dick Cepek Dick Cepek Denman (LTR, LTB), Conti General (P, LTR), Titan Tire (ATV), Specialty tires (racing, specialty, motorcycle) Double Coin China Mfrgs. All. Shanghai Tyre (MTR, MTLP) Douglas Wal-Mart Stores Kelly Dune Hopper Greenball Corp. Cheng-Shin (ATV) Dune Slider Greenball Corp. Cheng-Shin (ATV) Dune Tracker Greenball Corp. Cheng-Shin (ATV) Duralon Midstates Dist. Bridgestone/Firestone Durasteel Del-Nat Tire Corp. Cheng Shin (HP, metric) Dynastar Dynastar Int. Various Dynatex Dynatex Tire Off-shore Dynatrac Heafner China Manufacturing Association Eldorado Eldorado Tire Cooper (P, HP, LTR, LTB, MTB) Embassy Tire Alliance Grp. Kelly Euro-Tech Metric Tire Factory Continental General Tire Excelsior Coker Tire Specialty tires, Denman Fisk Discount Tire Michelin (P, LTR) Fleetwood Fleetwood Mktg. Freeway Greenball Corp. Cheng-Shin, various off-shore (LTB, bias trailer) Futura Pep Boys Cooper, Bridgestone/Firestone Gateway Dunlap & Kyle Denman (LTB, LTR, ATV, F/I-B), JK Tyre (india) (MTB), Titan Tire (ATV) Specialty tires (F/I-B) Goldenmark Triton Tire Kelly Greenmaster Greenball Corp. Cheng-Shin (bias golf cart) Greensaver Greenball Corp. Cheng-Shin (bias golf cart) Ground Buster Greenball Corp. Cheng-Shin (ATV) GT Reliable Tire Gajah Tunggal Guardian Amer. Car Care Michelin (P, HP, LTR, LTB) Guardsman Sears, Roebuck Kelly, Pirelli Tire Corp., Cooper Harvest King TBC Corp. Bridgestone/Firestone Kelly Hercules Hercules Tire Cooper (P, HP, LTR, LTB, MTB), Kumho (P, HP, LTR, MTR, MTLP), Woosung (P, LTR), Modi (MTB), Alliance (Israel) (F/I-R, F/I-B), China Tire (flotation-farm, LTB, MTB) Heritage Summit Tire Kelly, Dunlop, Double Coin Highland China Mfrgs. All. Various Homaster Greenball Corp. Cheng-Shin (mobile home) Hood Tire Centers Inc. Michelin North America (P, HP, LTR) Insa Premier Lucas Autom. Goodyear (Model A Ford car) Interco Interco Tire Various (LTR, LTB, ATV) Jetzon Jetzon/Telstar Kelly Jupiter Itochu Interntl. Woosung (Korea) (P, HP, LTR) Kirkland Signature Costco Michelin (P, LTR) Laramie Laramie Tire Kelly Lester Universal Vintage Denman, Specialty tires Lucas Lucas Autom. BFS, Denman, Trelleborg (Sweden), Nokian (Finland) (antique & classic auto, bias Model A truck) Mark 300 Triton Tire Kelly Maxima Tire Factory Continental General Tire Merit Hercules Tire Cooper (P, HP, LTR), Woosung (P, HP) Merlin Express Merlin Tire Modi (india) (MTB) Metro Gene Savage Tire Mickey Thompson Max Trac Tire Specialty tires (P-bias, LT-bias, racing, wide street), Cooper (P, LTB), Avon (racing) Mitco Super Solid Mitco Inc. Various Mohawk Indep. Tire Sales Yokohama (P, HP, LTR) Motomaster Canadian Tire Kelly, Michelin, Bridgestone/Firestone (P, HP, LTR) Mud Shark Greenball Corp. Cheng-Shin (ATV) Mud Buster Greenball Corp. Cheng-Shin (ATV) Multi-Mile TBC Corp. Cooper, Kelly National Del-Nat Tire Corp. Cooper (P, HP, LTR), Yokohama (P, HP, LTR), Toyo (P), Cheng Shin (P, HP, LTR, IND, lawn/garden, ATV, boat trailer), Denman (LTB, F/I-B), Alpha (LTB, MTB, IND), Alliance (F/I-R, F/I-B), Ceat (IND), China Manufacturers Alliance (MTR, MTLP), Cupples (tubes) Nitto Nitto Tire Toyo Nordic Orion Tire Corp. Hangzhou (China) (P, IND (pneumatic solid)), Yantai (solid), Yinchuan (LTB, MTB), Double Happiness (China) (LTB), JK Tyre (india), Vikrant Tyre (india), Pearl River Tire (China) (MTB) Orion Orion Tire Corp. Hangzhou (China) (P, IND (pneumatic solid)), Yantai (solid), Yinchuan (LTB, MTB), Double Happiness (China) (LTB), JK Tyre (india), Vikrant Tyre (india), Pearl River Tire (China) (MTB) Osprey Greenball Corp. Cheng-Shin (P) Outrigger OTR Wheel Titan, Specialty tires, Fidelity Pacemark TeamTBA Kelly Parnelli Jones Prog. Cust. Wheels Kelly Patriot Sears, Roebuck Cooper Phantom Discount Tire Michelin (P, HP, LTR, LTB) Pit Bull Orig. Tire Mart Various Pitchmaster Greenball Corp. Cheng-Shin (baseball pitching machine) Pos-A-Traction Pos-A-Traction Kelly Power King TBC Corp. Kelly, Hankook Denman Powermaster Greenball Corp. Cheng-Shin (go kart) Premium Sportway Fairmount Tire Denman, Fidelity (P low-rider applications) President President Tire Bridgestone/Firestone, Conti General, Michelin North America Pro Prof. Indust. Tire Various Pro Trac Coker Tire Specialty tires, Denman Pro Track Greenball Corp. Cheng-Shin (ATV) Ram Mimco Inc. Specialty tires Regul Heafner Michelin, Kelly (P, HP, LTR, LTB) Response Sears, Roebuck Yokohama Reynolds Reynolds Tire Conti General Roadeo Boots Roadeo Inc. Kelly RoadPro Hercules Tire P.T. Gadjah Tunggal (P, LTR) Rubber Master Countrywide Ind. Greenball (Taiwan) , P.T. Deli (Indonesia) Skandic Orion Tire Corp. Hangzhou (China) (P, IND (pneumatic solid)), Yantai (solid), Yinchuan (LTB, MTB), Double Happiness (China) (LTB), JK Tyre (india), Vikrant Tyre (india), Pearl River Tire (China) (MTB) Secura Greenball Corp. Cheng-Shin (LTR) Sentry Sears, Roebuck Cooper, Pirelli, Kelly Shell TeamTBA Kelly Shredder Greenball Corp. Cheng-Shin (ATV) Sidewinder Tire Factory Continental General Tire Sigma TBC Corp. Cooper, Kelly, Bridgestone/Firestone Signet Hercules Tire Cooper (P), Woosung (P, LT) Silvermark Triton Tire Kelly Solo-Tech Tire Factory Continental General Tire Sonic Parrish Tire Conti General Spartan Reliable Tire Co. Kelly, Various Stratton Indep. Tire Sales Summit Summit Tire Kelly, Dunlop, Double Coin Super Sport TeamTBA Kelly Superguard Sears, Roebuck Kelly, Cooper Tacoma Parrish Tire Cooper Telstar Jetzon/Telstar Kelly Temco Orig. Tire Mart Various TNT Tire Group Int. GRL Towmaster Greenball Corp. Cheng-Shin (boat trailer) Trail Handler Sears, Roebuck Pirelli, Kelly, Cooper Tredtech Parrish Tire Conti General & Yokohama Tribune Indep. Tire Sales Turnpike Parrish Tire Conti General Ultra-Tech Major tires Kelly, JK Tyre (india), Apollo Tyres (india) Nankang (P, HP, LTR, LTB, MTB) Universal Universal Vintage Denman, Specialty tires 76 Tosco Mkting. Kelly Vagabond Tire Factory Continental General Tire Vanderbilt Reynolds Tire Kelly Viper Sears, Roebuck Cooper Vogue Vogue Tyre Kelly Wearmaster OTR Wheel Titan Weathermark Triton Tire Kelly Westlake Foreign Tire Sales Various (off-shore) Winston Heafner Kelly Wynstar China Mfrgs. All. Shanghai Tyre (P, HP, LTR) YKS Foreign Tire Sales Various (off-shore) Ziggurat Tirex Inc. Tornel (Mexico) Vikrant Tyres (india) Shandong Triangle Group (China |
#17 |
Denman is out of business.
#18 |
Something that I do with my Semi Truck and trailer tires is instead of regular compressed air I use nitrogen. The nitrogen molecules are 3 times larger then regular air so you will not get a low tire when trailer is sitting for extended periods of time. And they run cooler also. I was pulling a triple axle cattle trailer and I had to replace the tires on two of the axles and I used the nitrogen the other had regular air, and when I fuel up I always feel my tires, the tires with the nitrogen were noticably cooler then the other ones.
#19 |
What about the 16 inch wheels in place of the 15 inchers. Where can you buy these?
I had a 28 foot pace and had 15 flats in 3 seasons. I tow a lot and tend to drive fast too. Traded for a 50 ft pace LQ with 16 inchers. 1 flat in 2 seasons. Bought a 48 ft haulmark (POS) trailer. 4 flats in 2 seasons 3 on the same hub. It has 15 inchers on it. I was'nt paying attention when I bought it or I would not have. Chip |
#20 |
Liked 69 Times in 30 Posts
Please remember that any tire presure over 60lbs when inflating a tire can kill you when the tire explode, one of the reasons that professional tire installer use a cage to protect themselves when inflating tires. I own a BlueBird Wanderlodge which tips the scale at just under 36.000lbs all tires are inflated by my local Goodyear tire company, usually when the tire technician inflates my tires he locks the air nozzle and walk away from the tire his inflating(I also follow his lead) Joe, follow Mr Teuton's advise, he know's a thing or two about mileage. I attented a Goodyear seminar for people driving an Rv with trailer or a truck and we were told to stop every two hours to let the tire cool down, gives the tire rubber and oil to cool down. I followed that rule and never had a flat in six year hauling an open wheel trailer with car and before that probably four blow out each year.Claude
