Old 07-07-2010, 07:23 AM   #11
Pistol Pete
Pistol Pete's Avatar
Liked 810 Times in 213 Posts
Default Re: Trailer Tires Part 2
Rich
Maxxis does have a E rated tire, so that's probably what i'm looking to buy.
Thx for the help.
Pete
Pistol Pete is online now   Reply With Quote
Old 07-07-2010, 08:14 AM   #12
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
Someone posted about taking heat gun readings on a trip.What temp range is of concern when taking the readings?Just facts,not speculation.Thanks.
Former NHRA #1945
Former IHRA #1945
T/SA
Old 07-07-2010, 09:27 AM   #13
Wade Mahaffey
Wade Mahaffey's Avatar
Liked 18 Times in 8 Posts
I also use a temp gun to regulate my brake adjustment. It only takes a minuite, when you stop to fuel up. you can shoot the tire and the hub quickly as you walk buy while fueling. This will identify any potential problem that will put you on the side of the road, and potentially cost a lot of $$$$. I will get under and adjust and/or investigate a reading in excess of 20% (hotter or colder) of the other wheels (6 in my case). Most of the time I'll be within 10% on my normal adjustment maintaince program. Also very important and potentially costly, check the bearings lube and replace as needed. I have the E-Z lube axles but don't use that feature, because of the chance of pushing the grease past the seal and into the brake shoe area. You know what happens next. I try to take the stuff apart once a year and replace as needed and hand pack the bearings.
Wade Mahaffey
Wade Mahaffey is offline   Reply With Quote
Old 07-07-2010, 01:35 PM   #14
Ed Fernandez
Thanks Wade.
Former NHRA #1945
Former IHRA #1945
T/SA
Old 07-07-2010, 01:46 PM   #15
Rich Biebel
Rich Biebel's Avatar
Liked 553 Times in 216 Posts
My Classic trailer has Nev-r-lube axle bearings.......I never heard of them before I bought the trailer. They are sealed bearing cartridges. Nothing to pack or adjust. I replaced all 4 when I did brakes. One set of shoes had NO brake lining material on either shoe....none! Was having issues stopping and after a little inspection I saw why. I replaced the bearing cartridges just so I would feel better.......One snap ring and they press in and out of the drums hub. All your supposed to do is inspect them for any obvious grease leaks and check the play by rocking the wheel with it off the ground......They are good so far and I kept the old ones for spares......they were also good...
High end travel trailers, like airstreams, have been using these bearings.
Rich Biebel
S/C 1479
Stock 147R
Old 07-07-2010, 03:09 PM   #16
Eddies66
Eddies66's Avatar
Liked 881 Times in 452 Posts
Who makes who:
PRIVATE BRAND TIRE SELLER TIRE MAKER
Advance China Mfrgs. All China Mfrgs.
Aerolon Lucas Automotive Denman (bias antique, classic automobile)
Aero Track Greenball Corp. Cheng-Shin (ATV)
Akuret Del-Nat Tire Corp. Yokohama (P, HP)
Alta Racer Greenball Corp. Cheng-Shin (Taiwan) (bias racing)
American Radial Amer. Car Care Michelin
Apache Tire Factory Continental General Tire
Apple I Frank's Tire
Arizonian Discount Tire Kelly (P, LTR)
Armour China Mfrgs. All. Jiangsu Tyre (IND)
Astra Tire Factory Continental General Tire
Astro Tire Group Int. Govind Rubber Ltd. (GRL) (india) Danubiana (Roumania) [farm] Madras Elastomeres (india) [solid IND] Chaoyang (China) [pneumatic IND] Roadstone (Thailand) [OTR, IND] Dong-Ah (Korea) [tubes, flaps]
Atlas TeamTBA Kelly
Betco Coker Tire Specialty tires, Denman
Big O TBC/Big O Kelly
Bilt-Mor Rott-Keller Co. Off-shore
Brigadier Reynolds Tire Conti General
Cambridge Dunlap & Kyle Various off-shore (MTR)
Candy Classic Fairmount Tire Dunlop (P-bias wide whitewall for classic cars)
Capitol Dynastar Int.
Coker Classic Coker Tire Specialty tires, Denman
Commander Coker Tire Specialty tires, Denman
CO-OP Triton Tire Bridgestone/Firestone, Kelly, Dunlop
Cordovan TBC Corp. Cooper, Kelly
Cornell Pep Boys Bridgestone/Firestone
Cosmo Tire Group Int. Chaoyang
Country Squire Triton Tire Kelly, Continental General
Custom Classic Lucas Automotive Bridgestone/Firestone, Denman (bias for classic cars 1930s-'50s)
Danzig Foreign Tire Sales Various (off-shore)
Delta Del-Nat Tire Corp. Yokohama (P, HP, LTR), Cooper (P, HP, LTR), China Manufacturers Alliance (MTR, MTB, MTLP), Cheng Shin (P, HP, LTR, IND, lawn/garden, ATV, boat trailer), Toyo (P), Denman (LTB, F/I-B), Alpha (LTB, MTB, IND, Alliance (F/I-R, F/I-B), Ceat (IND), Cupples (tubes)
Dick Cepek Dick Cepek Denman (LTR, LTB), Conti General (P, LTR), Titan Tire (ATV), Specialty tires (racing, specialty, motorcycle)
Double Coin China Mfrgs. All. Shanghai Tyre (MTR, MTLP)
Douglas Wal-Mart Stores Kelly
Dune Hopper Greenball Corp. Cheng-Shin (ATV)
Dune Slider Greenball Corp. Cheng-Shin (ATV)
Dune Tracker Greenball Corp. Cheng-Shin (ATV)
Duralon Midstates Dist. Bridgestone/Firestone
Durasteel Del-Nat Tire Corp. Cheng Shin (HP, metric)
Dynastar Dynastar Int. Various
Dynatex Dynatex Tire Off-shore
Dynatrac Heafner China Manufacturing Association
Eldorado Eldorado Tire Cooper (P, HP, LTR, LTB, MTB)
Embassy Tire Alliance Grp. Kelly
Euro-Tech Metric Tire Factory Continental General Tire
Excelsior Coker Tire Specialty tires, Denman
Fisk Discount Tire Michelin (P, LTR)
Fleetwood Fleetwood Mktg.
Freeway Greenball Corp. Cheng-Shin, various off-shore (LTB, bias trailer)
Futura Pep Boys Cooper, Bridgestone/Firestone
Gateway Dunlap & Kyle Denman (LTB, LTR, ATV, F/I-B), JK Tyre (india) (MTB), Titan Tire (ATV)
Specialty tires (F/I-B)
Goldenmark Triton Tire Kelly
Greenmaster Greenball Corp. Cheng-Shin (bias golf cart)
Greensaver Greenball Corp. Cheng-Shin (bias golf cart)
Ground Buster Greenball Corp. Cheng-Shin (ATV)
GT Reliable Tire Gajah Tunggal
Guardian Amer. Car Care Michelin (P, HP, LTR, LTB)
Guardsman Sears, Roebuck Kelly, Pirelli Tire Corp., Cooper
Harvest King TBC Corp. Bridgestone/Firestone Kelly
Hercules Hercules Tire Cooper (P, HP, LTR, LTB, MTB), Kumho (P, HP, LTR, MTR, MTLP), Woosung (P, LTR), Modi (MTB), Alliance (Israel) (F/I-R, F/I-B), China Tire (flotation-farm, LTB, MTB)
Heritage Summit Tire Kelly, Dunlop, Double Coin
Highland China Mfrgs. All. Various
Homaster Greenball Corp. Cheng-Shin (mobile home)
Hood Tire Centers Inc. Michelin North America (P, HP, LTR)
Insa Premier Lucas Autom. Goodyear (Model A Ford car)
Interco Interco Tire Various (LTR, LTB, ATV)
Jetzon Jetzon/Telstar Kelly
Jupiter Itochu Interntl. Woosung (Korea) (P, HP, LTR)
Kirkland Signature Costco Michelin (P, LTR)
Laramie Laramie Tire Kelly
Lester Universal Vintage Denman, Specialty tires
Lucas Lucas Autom. BFS, Denman, Trelleborg (Sweden), Nokian (Finland) (antique & classic auto, bias Model A truck)
Mark 300 Triton Tire Kelly
Maxima Tire Factory Continental General Tire
Merit Hercules Tire Cooper (P, HP, LTR), Woosung (P, HP)
Merlin Express Merlin Tire Modi (india) (MTB)
Metro Gene Savage Tire
Mickey Thompson Max Trac Tire Specialty tires (P-bias, LT-bias, racing, wide street), Cooper (P, LTB), Avon (racing)
Mitco Super Solid Mitco Inc. Various
Mohawk Indep. Tire Sales Yokohama (P, HP, LTR)
Motomaster Canadian Tire Kelly, Michelin, Bridgestone/Firestone (P, HP, LTR)
Mud Shark Greenball Corp. Cheng-Shin (ATV)
Mud Buster Greenball Corp. Cheng-Shin (ATV)
Multi-Mile TBC Corp. Cooper, Kelly
National Del-Nat Tire Corp. Cooper (P, HP, LTR), Yokohama (P, HP, LTR), Toyo (P), Cheng Shin (P, HP, LTR, IND, lawn/garden, ATV, boat trailer), Denman (LTB, F/I-B), Alpha (LTB, MTB, IND), Alliance (F/I-R, F/I-B), Ceat (IND), China Manufacturers Alliance (MTR, MTLP), Cupples (tubes)
Nitto Nitto Tire Toyo
Nordic Orion Tire Corp. Hangzhou (China) (P, IND (pneumatic solid)), Yantai (solid), Yinchuan (LTB, MTB), Double Happiness (China) (LTB), JK Tyre (india), Vikrant Tyre (india), Pearl River Tire (China) (MTB)
Orion Orion Tire Corp. Hangzhou (China) (P, IND (pneumatic solid)), Yantai (solid), Yinchuan (LTB, MTB), Double Happiness (China) (LTB), JK Tyre (india), Vikrant Tyre (india), Pearl River Tire (China) (MTB)
Osprey Greenball Corp. Cheng-Shin (P)
Outrigger OTR Wheel Titan, Specialty tires, Fidelity
Pacemark TeamTBA Kelly
Parnelli Jones Prog. Cust. Wheels Kelly
Patriot Sears, Roebuck Cooper
Phantom Discount Tire Michelin (P, HP, LTR, LTB)
Pit Bull Orig. Tire Mart Various
Pitchmaster Greenball Corp. Cheng-Shin (baseball pitching machine)
Pos-A-Traction Pos-A-Traction Kelly
Power King TBC Corp. Kelly, Hankook Denman
Powermaster Greenball Corp. Cheng-Shin (go kart)
Premium Sportway Fairmount Tire Denman, Fidelity (P low-rider applications)
President President Tire Bridgestone/Firestone, Conti General, Michelin North America
Pro Prof. Indust. Tire Various
Pro Trac Coker Tire Specialty tires, Denman
Pro Track Greenball Corp. Cheng-Shin (ATV)
Ram Mimco Inc. Specialty tires
Regul Heafner Michelin, Kelly (P, HP, LTR, LTB)
Response Sears, Roebuck Yokohama
Reynolds Reynolds Tire Conti General
Roadeo Boots Roadeo Inc. Kelly
RoadPro Hercules Tire P.T. Gadjah Tunggal (P, LTR)
Rubber Master Countrywide Ind. Greenball (Taiwan) , P.T. Deli (Indonesia)
Skandic Orion Tire Corp. Hangzhou (China) (P, IND (pneumatic solid)), Yantai (solid), Yinchuan (LTB, MTB), Double Happiness (China) (LTB), JK Tyre (india), Vikrant Tyre (india), Pearl River Tire (China) (MTB)
Secura Greenball Corp. Cheng-Shin (LTR)
Sentry Sears, Roebuck Cooper, Pirelli, Kelly
Shell TeamTBA Kelly
Shredder Greenball Corp. Cheng-Shin (ATV)
Sidewinder Tire Factory Continental General Tire
Sigma TBC Corp. Cooper, Kelly, Bridgestone/Firestone
Signet Hercules Tire Cooper (P), Woosung (P, LT)
Silvermark Triton Tire Kelly
Solo-Tech Tire Factory Continental General Tire
Sonic Parrish Tire Conti General
Spartan Reliable Tire Co. Kelly, Various
Stratton Indep. Tire Sales
Summit Summit Tire Kelly, Dunlop, Double Coin
Super Sport TeamTBA Kelly
Superguard Sears, Roebuck Kelly, Cooper
Tacoma Parrish Tire Cooper
Telstar Jetzon/Telstar Kelly
Temco Orig. Tire Mart Various
TNT Tire Group Int. GRL
Towmaster Greenball Corp. Cheng-Shin (boat trailer)
Trail Handler Sears, Roebuck Pirelli, Kelly, Cooper
Tredtech Parrish Tire Conti General & Yokohama
Tribune Indep. Tire Sales
Turnpike Parrish Tire Conti General
Ultra-Tech Major tires Kelly, JK Tyre (india), Apollo Tyres (india) Nankang (P, HP, LTR, LTB, MTB)
Universal Universal Vintage Denman, Specialty tires
76 Tosco Mkting. Kelly
Vagabond Tire Factory Continental General Tire
Vanderbilt Reynolds Tire Kelly
Viper Sears, Roebuck Cooper
Vogue Vogue Tyre Kelly
Wearmaster OTR Wheel Titan
Weathermark Triton Tire Kelly
Westlake Foreign Tire Sales Various (off-shore)
Winston Heafner Kelly
Wynstar China Mfrgs. All. Shanghai Tyre (P, HP, LTR)
YKS Foreign Tire Sales Various (off-shore)
Ziggurat Tirex Inc. Tornel (Mexico) Vikrant Tyres (india) Shandong Triangle Group (China
Eddies66 is offline   Reply With Quote
Old 07-07-2010, 03:14 PM   #17
7820
7820's Avatar
Denman is out of business.
7820 is offline   Reply With Quote
Old 07-17-2010, 11:13 PM   #18
Eric Kitzan
Eric Kitzan's Avatar
Cool Re: Trailer Tires Part 2
Something that I do with my Semi Truck and trailer tires is instead of regular compressed air I use nitrogen. The nitrogen molecules are 3 times larger then regular air so you will not get a low tire when trailer is sitting for extended periods of time. And they run cooler also. I was pulling a triple axle cattle trailer and I had to replace the tires on two of the axles and I used the nitrogen the other had regular air, and when I fuel up I always feel my tires, the tires with the nitrogen were noticably cooler then the other ones.
Eric Kitzan is offline   Reply With Quote
Old 07-18-2010, 07:50 PM   #19
THE LEGEND
What about the 16 inch wheels in place of the 15 inchers. Where can you buy these?
I had a 28 foot pace and had 15 flats in 3 seasons. I tow a lot and tend to drive fast too.
Traded for a 50 ft pace LQ with 16 inchers. 1 flat in 2 seasons.
Bought a 48 ft haulmark (POS) trailer. 4 flats in 2 seasons 3 on the same hub.
It has 15 inchers on it. I was'nt paying attention when I bought it or I would not have.
Chip
THE LEGEND is offline   Reply With Quote
Old 07-18-2010, 08:30 PM   #20
cicero819
cicero819's Avatar
Liked 69 Times in 30 Posts
Please remember that any tire presure over 60lbs when inflating a tire can kill you when the tire explode, one of the reasons that professional tire installer use a cage to protect themselves when inflating tires. I own a BlueBird Wanderlodge which tips the scale at just under 36.000lbs all tires are inflated by my local Goodyear tire company, usually when the tire technician inflates my tires he locks the air nozzle and walk away from the tire his inflating(I also follow his lead) Joe, follow Mr Teuton's advise, he know's a thing or two about mileage. I attented a Goodyear seminar for people driving an Rv with trailer or a truck and we were told to stop every two hours to let the tire cool down, gives the tire rubber and oil to cool down. I followed that rule and never had a flat in six year hauling an open wheel trailer with car and before that probably four blow out each year.Claude
