Old 07-27-2010, 08:47 AM   #1
SAMATCOTOOLSMAN
Wink Steering wheel disconect hub
Need feedback,info and advice regarding best type/brand of steering wheel disconNect device.(removable steering wheel hub).
Will be used on stock gm column with a grant wheel.also must meet sfi 42.1 spec.
Thank you!
SAMATCOTOOLSMAN is offline   Reply With Quote
Old 07-27-2010, 09:04 AM   #2
Larry Curtis
Larry Curtis's Avatar
Liked 9 Times in 2 Posts
Default Re: Steering wheel disconect hub
I have a Mark Williams disconnect. It is a real nice unit.
Larry
Larry Curtis is offline   Reply With Quote
Old 07-27-2010, 12:47 PM   #3
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Grant #3001 or 3021 are splined for the GM shaft.and 5 bolt pattern .......only difference is one is silver the other is black........I've used these,they bolt directly onto the GM shaft and they are SFI.......Tom
Old 07-28-2010, 06:23 PM   #4
Jim Carter
Liked 19 Times in 3 Posts
Smile Re: Steering wheel disconect hub
Het Sam:
Kalak (sp?) had a steering wheel disconnect on his gorgeous Vette at Atco. Maybe someone has a contact no. for him so you'se could talk to him.
Say hello to Big Stash for me.
Jimmie C.
Jim Carter is offline   Reply With Quote
