Old 07-28-2010, 11:01 AM   #11
Liked 1,829 Times in 414 Posts
Default Re: Oldsmobile oil system mods
What brand and part number lifters are they?
Old 07-28-2010, 12:12 PM   #12
SSDiv6
Liked 1,583 Times in 582 Posts
Originally Posted by Glenn Briglio View Post
I checked out three different sets of lifters. Checked the diameter of the orifice going into lifter and location of orifice. Also checked diameter of pushrod cup and they all were within .002.
Make sure they are Oldsmobile lifters and not Chevy. The Oldsmobile/Pontiac lifters has the band and orifice at a different location.
Old 07-28-2010, 01:58 PM   #13
Bill Edgeworth
Comp cams #863 lifters are a decent off the shelf lifter for these motors.
NEVER use a Chevy lifter in a BOP application as SSDiv6 mentioned the BOP lifter is taller and has the band further up the lifter. If you use a cam with a small base circle the band can be exposed at the bottom of the lifter bore with a Chevy lifter. Not only will you then have an oil problem but you loose support of the lifter in the bore and that could (will) lead to catastrophic failure. While were on the subject of valve train, guide plates are now legal for the Oldsmobile heads you don’t want to run without them!
Bill Edgeworth 6471 STK
Bill Edgeworth is offline   Reply With Quote
Old 07-31-2010, 02:34 PM   #14
Run to Rund
Liked 54 Times in 27 Posts
As noted above, you don't need cam bearing oiling restrictors. However, don't drill new holes 180 deg. away or the original hole will be right under the bolt that holds the baffle plate. Drill the new hole around 160 degrees away and you will be fine. The Chevy lifters I have seen meter too much oil to the pushrods. With solids you can drill the lifter oil feeds to .135" and red loctite in allen set screws that you have heated red hot to detemper them and then drilled with a .040" bit.
