#11 | |
Liked 28 Times in 11 Posts
EX 5-Doorstocker |
#12 |
For those interested, Jere still has all of those news letters, they're available for free on his web site. Jere is still extremely active, and one of the sharpest people I know, and not just about headers, but cam design, data acquisition, dyno operation, and racing in general. He's a lot like Bill Jenkins and Warren Johnson, he's a contrary old codger, but if you can talk sense and knowledge to him, there's a ton of information he has to offer. But he is completely intolerant of B.S. or people that waste his time.
Alan Roehrich 212A G/S |
#13 |
I have read that equal length primaries (assuming proper diameter) will deliver the most power but in a narrow RPM band, Running different length primaries will lower the peak HP but broaden the HP curve delivering higher average HP over a larger RPM band.
It seems to me that higher average HP should be the goal for a drag motor.
Stock - 5013 |
#14 |
If the primary length varies enough that some primaries are off enough to lower the amount of HP produced by those cylinders, they'll just lower the overall average HP, in the vast majority of cases.
The reason is that you have an approximately 3" "window" for tuned length. After that, the length of the primary is far enough from the correct harmonic length that it hurts HP over the entire range. That happens because you lose way more off the peak than you ever gain everywhere else. The "tuned" in the term tuned equal length header refers to the length of the primaries and the collector being tuned to one of the natural harmonics created by the rest of the combination, cam timing, port size, bore, stroke, rod length, etc. If the primary and the collector do not match one of those harmonic lengths, you are not operating in a "tuned" state, and therefor the header is not working with the engine, it is working against it, by disrupting those harmonic tuning lengths. That's a crude layman's way of explaining it, used here for the sake of brevity and clarity. Obviously, given the constraints imposed by the stock engine location, mostly stock chassis, and ground clearance on a Stock or Super Stock car, it is next to impossible to build absolutely perfectly tuned headers. In some cases, it can be impossible to even get within the 3" "window", at least on the primary tubes, no matter what you do. Also, in some cases, even if you add extra bends to move a tube to get close to the window, between the extra bends and the inch or two that end up from perfect, you're better off to just use fewer and/or less severe bends and live with the incorrect length.
#15 |
Liked 279 Times in 68 Posts
There are a couple of things I have observed over the years about headers on my car that may or may not be true for others. #1 Is that a dyno is not the place to test headers. Mike Keown told me years ago a bigger header will make more power on the dyno but won't go down the race track like it shows on the dyno and that has been my experience. #2 is what I heard from a really good header builder and that was that the first 8 inches of the primary tubes were the most important part of a header and the size of the first step should match the port size. These are just my experiences on my car and probably aren't relevant for every one else.
Greg Hill 4171 STK |
#16 |
I experienced what Greg mentioned about big headers on the dyno. I quit drag racing in 1980 and went dirt track racing. I had a 358" methanol burning, Hilborn injected engine on Carroll Caudle's dyno, and tried a set of his 2" dyno headers just for grins. My thinking was if my 292" C/SM Camaro liked 2" headers (It did. Thanks Garly), so this 358" should. On the dyno it did, it was up everywhere, as much as 40 ft lbs. Bought a set for the car. It was just plain lazy. My driver said it felt like he was towing something. Finally listened to him and put the smaller ones back on it and it stepped right back up.
Guess we don't race dynos, right? ![]()
Ed Wright 4156 SS/JA |
#17 | |
Liked 244 Times in 26 Posts
What does a superflow test at, 300 rpm/sec correct? I think that is still slower than the accel rate in high gear, but it's been a long time since I've looked at that. |
#18 |
Chris, that acceleration rate is selectable. Too many years ago, so I don't remember what Carroll was using that day. Most guys use what is closest to their car pulls in high gear. With that dirt car, I have no idea what that would be. No data logger. We had no minimum weight, so if you tossed it up and it came back down, if we could get by without it we didn't use it.
#19 |
Liked 56 Times in 27 Posts
Has anyone done any testing with extentions on merge collectors, also adding to primary tubes ? thanks, in advance.........
Dave Ribeiro 1033 STK |
#20 | |
Liked 165 Times in 59 Posts
had a set of hookers 1 7/8 primarys with 3 1/2 collectors ,,added extensions and picked up 2-3 hundreths ,,then i built a set of steps with a smaller collector size,merg collector and picked up about 3 hundreths ,,now this is track results and over many runs and conditions this was the average gmonde |
