Old 07-30-2010, 06:28 PM   #1
STUDENT
Default Foot brake with or without 2 step
I am new to the stock eliminator world. I am unsure what will work better.
Leaving the staring line with or without the use of the 2 step.
Pro and cons please both in performance and reaction time.
I have raced many stick cars, this will be the first automatic car without a transbrake.
Thanks for the help.
STUDENT is offline   Reply With Quote
Old 07-30-2010, 07:06 PM   #2
Liked 1,907 Times in 427 Posts
Default Re: Foot brake with or without 2 step
It depends a great deal on the style of the driver and the car he is driving.
Old 07-30-2010, 07:16 PM   #3
Patrick Kelliher
My reaction times improved dramatically since removing the 2-step. Some people can't live without it. Honestly the only way to know is to try both methods yourself.
Patrick Kelliher is offline   Reply With Quote
Old 07-30-2010, 08:52 PM   #4
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
the two step can help or hinder,,,,if your racing a lower class car that has leaves easy working off the two step may help you reaction time,but on the other hand if you have a spot on the bottom bulb where you are constistant with just foot braking and you are good there ,,be carefull you might find yourself going red, if you two step off the brake pedal, its easy to let off a loaded brake pedal that it is to plant the right foot ,,test to see ,,the only reason i use it ,is for the stock carb is not consistant leaving foot braking ,,,if your combo has using a holley dp or even a q-jet keep foot braking ,,gmonde
Old 07-30-2010, 09:56 PM   #5
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
Talking Re: Foot brake with or without 2 step
I just put one in.I'll let you know on Aug. 22nd how it worked.:>):>)
Former NHRA #1945
Former IHRA #1945
T/SA
Old 07-31-2010, 09:05 AM   #6
jim powers
jim powers's Avatar
Liked 13 Times in 10 Posts
ed, your such a liar !!!!!you know it works killer!!
jim powers is offline   Reply With Quote
Old 05-16-2011, 04:42 PM   #7
Jim Rodgers
How do you set up a 2 step with foot brake? Is there a performance advantage to using a 2 step with foot brake?
Jim Rodgers is offline   Reply With Quote
Old 05-16-2011, 05:02 PM   #8
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
Good info in this thread Jim.
http://classracer.com/classforum/showthread.php?t=33374
Bob Pagano A/SA
Old 05-16-2011, 05:17 PM   #9
Richard Grant
Richard Grant's Avatar
Liked 13 Times in 7 Posts
You will only find out which way is best by installing the two step and trying both ways.
No matter what anyone tells you they can only comment on their car and their driving style. You have to try for you self to know the correct answer.
Richard Grant 4988 STK
Richard Grant is offline   Reply With Quote
Old 05-17-2011, 08:27 AM   #10
Eric Merryfield
Eric Merryfield's Avatar
Liked 502 Times in 130 Posts
Keep it simple.....footbrake till your driving style or car proves it to you that you need to spend the time effort and dough on a two step......Since your suspension hasn't been preloaded before(stick/trans brake) concentrate on getting that right first with decent 60 foot times, etc. I have done it both ways, footbraking is more adjustable and the method of choice for quite a few world champions....But until you/car prove its needed, go off the brake pressure gauge and your bored clutch foot.
Good luck, I am going the other direction soon on my favorite car.
Eric
Eric Merryfield 1883 STK
