Old 07-31-2010, 06:51 PM   #21
SS 230
Default Re: bog
bill, did you fix your problem,if so what was it?
SS 230 is offline   Reply With Quote
Old 07-31-2010, 09:10 PM   #22
Monte Howard
Monte Howard's Avatar
Liked 71 Times in 23 Posts
Default Re: bog
Check your choke pull-off also.
Take the Vacum Line off the carb,push in the arm ,and put your finger over the vacum hose.
Then let your finger off the vacum line and make sure the arm comes out fairly smooth, or just put a new one on and make a run.
Monte Howard 3209 STK, 3208 SS
Monte Howard is offline   Reply With Quote
Old 07-31-2010, 11:18 PM   #23
Grant Eldridge
Grant Eldridge's Avatar
Default Re: bog
Re/ the pull-off, on my car I found it important to bend the link so that, when the pull-off is fully pushed in, the air valve can only open a hair, maybe .010-.020". There is an enrichment circuit that is exposed to airflow as the front edge of the air valve begins to open which could cause excess richness if it is exposed at idle or when you're up on the converter. I cured a problem on my car by bending that link so that the air valve could not begin opening until the pull-off began to relax as vacuum dropped. My understanding is that this hole acts as a secondary accelerator circuit, drawing fuel into the secondary side to transition until the main circuit is providing sufficient fuel. One of the carb guys could explain this much better, but it is another Qjet thing to check.....
Grant Eldridge is offline   Reply With Quote
Old 07-31-2010, 11:34 PM   #24
Default Re: bog
Note : Bill said he's leaving off a two step so the carb butterflies would be WFO on the line.
The choke pull off (vacuum break ) doesn't have as much importance in that situation.
The secondary accelerator pumps are made to function as soon as the flapper starts to open. In this situation , it would already be open or pulsing it's way to open.
Old 07-31-2010, 11:39 PM   #25
Bill Bogues
Bill Bogues's Avatar
Liked 169 Times in 53 Posts
Red face Re: bog
No, I haven't fixed it yet but it's not from lack of trying. I've changed or worked on everything that has anything to do with the car leaving the line and It still comes back to haunt me .I thought I had it fixed at the pro-am race in Baton rouge: Ran fri- sat- and sunday with no problems.Car had good 60' ft times (high 140's) and then at my last pass in elim's it bogs 300 rpm's, goes a 153, and I lost. I haven't ran it since but I'm reasonably sure it's fuel related. Thanks for reply on air valve ; I checked to see if it's working but I didn't check what you said you looked at. It's hard to get something lined out when you don't race a whole lot.
Bill Bogues 4696 STK
Bill Bogues is offline   Reply With Quote
Old 08-01-2010, 05:35 AM   #26
Bill Grubbs
Liked 564 Times in 66 Posts
Default Re: bog
Do not think this is crazy, however are you absolutely, 100% sure your foot is staying in the gas? We chased this problem for 2.5 years only to find that the two step made the carleave so hard (picked up .05 in the sixtey) that the seat gave enough for the accelerator to move. Just a thought.
Bill Grubbs is offline   Reply With Quote
