Old 08-02-2010, 01:46 PM   #1
Paul Ceasrine
Liked 10 Times in 10 Posts
Default Worst Performance Car You Ever Owned!
I'm not going 'First'.
Paul
Old 08-02-2010, 02:04 PM   #2
Alex Denysenko
Alex Denysenko's Avatar
Liked 4 Times in 3 Posts
Default Re: Worst Performance Car You Ever Owned!
Every Mopar 273 Power Pack A body car I owned and I had a bunch of those turds.
All were dogs in the real world, I don't care what road tests you read.
Those that were prepped for stock weren't much better as my Mustang ate them for breakfast in class during the 70's.
But by far the worst excuse for a performance car was the 1965 Coronet 426 street wedge I bought from work to flip in 1973.
Looked good, but what a dog even after a new clutch good tune up. High 14's.
Alex Denysenko NHRA 3038 SS, 3305 STK - IHRA 6 SS, 330A STK
Moneymaker Racing LaPorte Indiana 219-861-1214
www.moneymakerracing.net
Alex Denysenko is offline   Reply With Quote
Old 08-02-2010, 02:35 PM   #3
Paul Ceasrine
Alex,
i'm glad you started it off with a 273.
They could run decent if you did things correct.
My 67' Cuda 273/235HP convertible automatic was an outright 'DOG'
at first.
Rebuilt the engine at my fathers shop,
* .040 Mopar 10.5-1 pistons
* Re-ground crankshaft .010 rods/.010 mains (Re-balanced)
* High-Volume oil pump
* Windage Tray
* Sealed Power double-roller timing chain
* Sealed Power solid lifter camshaft .425 lift / w/258* duration
* 3/angle valve job on the heads, w/340 exhaust valves (1.60)
* 340 (240 lb. valve springs)
* Heads milled (.012) Compression ratio (approx. 11.0-1)
* Edelbrock aluminum Dual-plane high rise intake
* Carter 500cfm AFB (re-jetted)
* Accel Dual-point distributor
* Accel Super Coil
* Belden Ignition Wires
* Flex-A-Lite 6-blade fan
* Holley High Pressure fuel pump
* Cragar Headers (1 1/2" primary / 3" collector / medium tube length)
* B & M Shift Improver Kit (A-904 transmission)
* B & M Shifter
* 3.23 Sure-Grip Posi
* Plus a host of other bolt-on items (ie; Tach, Slotted mags, Gabriel's)
At age 15 went down the track, thought I was flying. Went down the return road, got to the timing slip booth, and was expecting a time-slip with at least a 15.20 on it.
The guy in the booth hands me a time-slip with a 17.27 on it. I tell him
he's given me the wrong time slip. He' says 'Oh No', I saw you go down the track, and this slip is correct. And follows up with 'Your car is slow'.
I get back to the pits, and everyone says "why didn't you get on it'.
I reply,' if I pushed the gas-pedal down any harder, my foot would have
went through the floor-board'.
I wanted to run at least low 15.00's. Of course, I overhead someone say
'the only way that car could run in the low 15.00's, is if you pushed it off the top of a mountain'.
What did they say, 'You need gears, you need a better camshaft, you need a transmission and converter'.
Part I
PC
Old 08-02-2010, 02:45 PM   #4
k.pascoe
Paul, Not sure if you mean the "slowest" or the worst.
My worst a 2004 Mustang Cobra tuned to 500+ hp. Axle hoppin' girl's car. Man I hated that thing.
The slowest; 1973 Gran Torino Sport with a 429 and a C6... slug.
k.pascoe is offline   Reply With Quote
Old 08-02-2010, 02:52 PM   #5
Mike Carr
Mike Carr's Avatar
Liked 83 Times in 37 Posts
While certainly not a performance car, my first street car was a 1979 Cutlass. 260 V8 two barrel. Rated 110 HP. The only modifications I ever did at the track was take the air cleaner base and stuff off, so when you opened the hood, nothing was on/around the carburetor like a Super Stock car. Weighed about 3,570 with me across the scales (no spare tire, jack, tools, etc). Ran a best ET of 18.59 at Quaker City in October 2000. Best mph I believe was 74 mph at Keystone (now Pittsburgh) that same year in August. It was a full second and 2 mph slower than Billy's HF/SA '85 Sunbird 110 cid 4 cylinder rated at 85 HP (of course, the Sunbird was about 1,200 pounds lighter).
Old 08-02-2010, 03:26 PM   #6
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Cool Re: Worst Performance Car You Ever Owned!
My 65 426 Plymouth was a dog to but a little better than yours. Mid to high 13's with gears, headers, and M/T 7 inch slicks. It was an automatic with a stock converter. I drove it to work so I couldnt get real crazy with stuff. . Just an over grown 383.
Old 08-02-2010, 03:40 PM   #7
KEN BUGAJ
Liked 18 Times in 7 Posts
My 67 Corvette 327/250 4 speed
All Stock it was a DOG !
KEN BUGAJ is offline   Reply With Quote
Old 08-02-2010, 03:51 PM   #8
Michael Kilduff
I had two that would qualify as the worst performance cars I ever owned.
1981 corvette and a 1980 Indy Pace Car Trans Am.
At least the TA handled great and looked good. Not sure what that turbo was for, asthetics maybe?
Michael Kilduff is offline   Reply With Quote
Old 08-02-2010, 03:57 PM   #9
smracer2002
70 Charger 318 2bbl/904/2.xx gears and 275/60/15 tires
in the back.
12.31 in the 1/8, low gear all the way out.
First On
Race
Day
smracer2002 is offline   Reply With Quote
Old 08-02-2010, 04:20 PM   #10
Paul Ceasrine
1970 Pontiac GTO.
400/350HP, 4-speed
With the 'Endura' color-coated bumper.
Hood-mounted tach (which didn't work)
3.23 open-end rear.
Could have plastered that car with;
'Here's a 15.90' car'
'Wide-Track'!!! The front-end suspension was the worst.
Car ate ball-joints and wore out front tires like crazy!
Had to rotate the tires every 2500 miles / every oil change.
