Old 08-04-2010, 03:53 PM   #1
Bobby Zlatkin
Bobby Zlatkin's Avatar
Default 2 PVC valves
Anything wrong with having a PCV valve in each valve cover and connecting them with a T-fitting into the carb?
I'm changing to an air cleaner base that doesn't have provision for the hose from the other valve cover.
Any disavantage?
Bobby & Norene Zlatkin L/SA
Bobby Zlatkin is offline   Reply With Quote
Old 08-04-2010, 04:06 PM   #2
SSDiv6
Liked 1,603 Times in 583 Posts
Default Re: 2 PVC valves
Any disavantage?
In the past, the use of two PCV's has been not allowed. Been told it must be OEM configuration. many eliminate them and install K&N breathers on both valve covers.
Advantages? It depends how much leak down you have on the engine.
Old 08-04-2010, 04:28 PM   #3
danny waters sr
danny waters sr's Avatar
Thumbs down Re: 2 PVC valves
Bobby, I tried it and it did not like it.We talkin 283 stocker here.
Old 08-04-2010, 06:32 PM   #4
Tom Meyer
Liked 354 Times in 120 Posts
I run it on my 283 super stock car it has been a while but it did pick my car up, Patterson along with casill have it on there 283 also. It did have more vacume than hooking it up to the header. I was told 1 to 2 hp on the dyno on a super stock motor don't know about stockers. Q jets don't like it I am told. It may have somthing to do with the ring package one is useing. Tom
Tom Meyer 5240 SS Stock ???
Old 08-04-2010, 06:48 PM   #5
SSDiv6
Yes, engine seal and ring package has a lot to do,
