Old 08-05-2010, 10:05 AM   #1
ss wannabee
Liked 7 Times in 7 Posts
Default GM 700-R4 questions.....
Sorry for the non-performance questions...but my street vehicle ('88 s10 Blazer-2.8) lost both TCC and overdrive a few months back. When I say "lost"...they both come back from time to time....but VERY intermittent...Yeah, the truck should be in a boneyard...it has about 265K on it but still runs.... The other shifts seem ok...trans doesn't seem to be slipping...but I try to avoid highway driving...it's tough in 3rd gear...also the "check engine"
light comes on when doing over 50 with that high-mileage V6 screaming...but I think that's the vehicle speed sensor asking the computer...."where's overdrive?" I adjusted the TV cable with little results.....
I've been driving the truck anyway with mostly city driving and it does ok...but eats a bit more gas...Want to fix for highway diving...and want to try a "fix" WITHOUT complete over-haul.
Was thinking replace the TCC solenoid...and do a valve body cleanout...am I headed in right direction? Not sure if I want to drop the v/body....(too many pieces to lose)....how about a pour-in cleaner in this case? How about a product called "Sea-Breeze"...anybody use this stuff?
ss wannabee is offline   Reply With Quote
Old 08-05-2010, 10:42 AM   #2
Liked 1,909 Times in 427 Posts
Default Re: GM 700-R4 questions.....
Do not put Sea Foam in a transmission. Sea Foam is a good product, used in your fuel system. You might try a can of Trans Medic, followed by a complete fluid and filter change (if you do that, please make sure the old filter seal is removed before you install the new filter).
Have the computer scanned to see exactly what codes it has.
If the rest of the shifts have a normal feel and occur at the correct time, the TV cable is adjusted close enough that the cable is not causing a problem with OD and lock up.
Fourth gear, AKA over drive, should occur around 38-48 MPH under normal conditions on a level surface, followed shortly afterward by lock up, there are two separate events. Fourth is normally supposed to happen first, then lock up at around 45 MPH. Sometimes, on certain vehicles, lock up can happen first, leading to a somewhat harsh 3-4 shift. They also sometimes happen at the same time, leading to a stacked shift feeling.
Fourth gear is strictly a mechanical and hydraulic function, there is no electrical signal involved. Fourth gear is a combination of the 3-4 clutches and the 2-4 band, so if you have 2nd gear and 3rd gear, you have the friction materials to have 4th gear. If the vehicle will take off from a complete stop with the gear selector in D or OD, the over run sprag is good. So, if you have 2nd gear, 3rd gear, and do not need manual low (L1) to take off from a standing stop, you have what is necessary for OD or 4th gear. At that point, 4th gear becomes a valvebody problem, or possibly a servo problem. The servo is on the passenger side of the case, behind the filler tube, in front of the TV cable. It's the large round piece. I would not advise you fool with it if you are not well versed in transmission work.
It is possible that, the TCC solenoid is bad, the o-ring on the end of the solenoid is bad, one of the pressure or temperature switches that is in line with the TCC solenoid is bad, the brake light switch is bad, a fuse is blown, or you have a bad ground.
I would start with the fuse panel, then check the brake light switch (the part that controls the lock up solenoid is on the end, not on the side, there are two, 2 wire connectors). Any slight pressure on the brake pedal, or adjustment problem, can open that switch and stop lock up from happening. Then look for a vacuum switch on the firewall. Check power to the vacuum switch, and then check vacuum.
Old 08-05-2010, 12:00 PM   #3
Rob Petrie E395
Liked 216 Times in 77 Posts
When you pull the pan off disconnect the TCC solonoid and measure it with a ohm meter. If its more than 30 ohms its junk. Not a real uncommon problem and cheap to fix. To adjust the brake light switch start the truck and push the pedal down there will be a little *** hanging down off the switch push the *** back towards the seat and let the pedal go and its adjusted. The switch can be the problem too but if the truck has antilock brakes it will usually set a antilock brake code before it will start overriding TCC lockup. If the light on the dash stays on even when the emergency brake is off start with the switch adjustment and clear the code before pulling the pan it might save you some work. Another common problem on these trucks is 2 foot drivers (using one for the brake and the other for the gas) if you drive like this it will cause all kinds of problems with TCC & antilock brake codes.
Hope this helps
Rob
One more thing I just thought of check the fuse for the cigerette lighter. On some of these trucks the cig lighter and the tcc solonoind are on the same fuse. I know its stupid but its the way they did some of the trucks back then.
Old 08-05-2010, 12:19 PM   #4
Thanks Rob. I never can seem to remember it all. I always forget some of the stuff I should remember, no matter how much I remember.
Old 08-05-2010, 04:29 PM   #5
Rob Petrie E395
Hey I forget more than I can remember LOL! I just work on alot of trucks being in farm country and if you could see some of the stuff that comes into my shop you would know why I remember the older stuff better than the newer stuff. Some days I would kill to do a oil change on a nice new one.
Old 08-05-2010, 08:01 PM   #6
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
This is a cable operated transmission, and shifts based on road speed and throttle cable position. As an engine loses power, when it is old and worn out, or out of tune, you have to step on the throttle more to get the vehicle down the road. Sometimes we have seen this happen if the catalytic converter gets plugged. Many times these old vehicles are so weak, the throttle position needs to be opened so high that all the upshifts feel delayed, the fourth gear shift is at a higher mile per hour then you are going. Does the transmission shift into overdrive if you backoff the throttle but downshifts back into 3rd if you step back into throttle , to maintain road speed ? Same could be happening with the TCC. There is a throttle position load release for TCC. So once the TP is higher than a calibrated number, say 30% then TCC will not come on.
Old 08-06-2010, 10:44 PM   #7
Greg Reimer 7376
Liked 719 Times in 220 Posts
Cool Re: GM 700-R4 questions.....
I have a 91 Chevy Silverado 1500 pickup,350,TBI,700R4, and it did that. Brake light switch worn out. It kept the TCC and the cruise control from working. Replaced it, truck is fixed. Try that first.
Old 08-07-2010, 11:12 PM   #8
Greg Reimer 7376
I just had another thought regarding the issue your S-10 Blazer has. It seems that the computer PROM in the GM computer is probably expecting to see a drop in engine RPM after 50 or so MPH,and it doesn't see it. If the torque converter clutch is not applying,it's in a mode of less than 1:1. It's a pretty loose converter, so the discrepancy is being seen between the vehicle speed sensor(which also runs the speedometer), and the engine speed sensor, which is picked up probably by the tach signal in the distributor. The person who suggested that you test the torque converter clutch apply solenoid for proper operation made a good suggestion.The diagnostic trouble code(DTC) would be caused by that excessive engine RPM at that road speed and that seems to all make sense. Identify the DTC, and that should make a proper diagnosis probable. Since you indicated that it was an intermittant condition,then got worse, it's probably something like that. If the trans fluid is all brown,smelly, and full of big particles, then that was probably the result.Good luck with your project!!
Old 08-08-2010, 08:20 PM   #9
ss wannabee
Default Re: GM 700-R4 questions....are
Thanks for all the responses...Unfortunately, work and family issues took up most of my spare time this weekend and had little time to investigate. I DID manage to get a hold of a GM service manual for the vehicle...and it has diagnostic troubleshooting charts which
mentioned most of the stuff you've said. Looks like I can electrically test the solenoid and
brake switch through the ALDL connector with a test light...and I'll do so. BTW, the Blazer
doesn't have antilock brakes...I think they came a year or two later. The trans fluid seems ok in color and smell on the stick...What I might do is just CHANGE the solenoid anyway along with the filter and fluid. I bought the piece some months ago...but I'll check the resistance Rob..just to see...I saw that the GM manual says the sol. is "junk" if it measures LESS than 20 ohms,,,,maybe the working "spec" is 20-30 ohms? Alan...you mentioned a "stacked shift" situation...YES this vehicle has done that...ALSO intermittently for the last 10 years or so....sometimes loading up the vehicle so badly that I'm forced to downshift. That's one reason why I'm leaning towards solenoid replacement. The Blazer is driven in the overdrive position..it works fine...no need for manual shift.
Old 08-08-2010, 08:45 PM   #10
ss wannabee
Forgot to mention but the tech at the garage next to work has been too busy to scan the vehicle. So I tried the "old-school" method with a paper clip and counted the flashes. What I got was Code 32...which is an EGR system malfunction. I watched through 3 or 4 cycles to make sure it was the only code....It was....NOT sure if the scan tool could "find" more...but it can give engine temp,TPS voltage, and other stuff that might be relevant. I'll still try to have that done. I don't think this is related to the trans problems but.....I want to point out that this code "sets" ONLY when I attempt to drive the Blazer on the highway...and the engine rpm is over 3,000...heading to 4,000 when the overdive doesn't work. When the o.d. is working properly, I don't think the engine speed goes over 3 grand...and I highway drive at the speed limit...I "baby" the vehicle...Whoever mentioned "easing" up on the throttle to get overdrive...I've tried that recently...NO results lately...although it has worked in the past.... I don't think the converter is clogged...perhaps the opposite....NOW it's time to try some things.....Thanks again, Guys!
