Old 08-13-2010, 07:07 AM   #1
George Mirza
Question SB Mopar Valve springs?
Looking for a good valve spring for a 340 stocker motor. This is for a stock type lifter, not Schubeck/Smith.
George Mirza is offline   Reply With Quote
Old 08-13-2010, 08:09 PM   #2
GTX JOHN
Default Re: SB Mopar Valve springs?
Isky 3105 (I think) 1.47 od set up @ 165 lb at 1.68......may need to shim again after 100 passes. If you need more info
racer7411@yahoo.com John Irving
Old 08-14-2010, 03:48 PM   #3
Jeremy
I have used the Howards 98215 "Zero Tolerance 1.25 Drop in springs, they have good pressures, and there a small diameter Chevy spring that give lots of rocker arm clearance.
Good Luck
Jeremy is offline   Reply With Quote
Old 08-14-2010, 07:27 PM   #4
older racer
Liked 68 Times in 26 Posts
hi, the comp cams, 926 -16 is a tough spring, fits great in a 340. has a high spring rate.
older racer is offline   Reply With Quote
Old 08-14-2010, 08:00 PM   #5
George Mirza
Thanks guys,
John
I have used the Isky 3105 in the past, I got them from Don Studley. He used to coat them. They seem ok, but I'm looking for a little bit more pressure, Isky catalog put them at #130@1.700 and #320@1.200. I miss talking with Don, he was a nice man.
Old Racer,
I have been using the Comp 926, but I put a new set in at the beginning of the season, set them up the same as the last ones and they must be junk, lost a good 500-700 finish line rpm from the old springs. Unfortunately I didn't test them before I put them in. I wonder if anyone else has had a problem with this spring?
Jeremy,
Did you have to machine the spring seats to get the Chevy spring to fit?
Thanks again,
George Mirza 1236 D/SA '71 340 Duster
Old 08-15-2010, 07:59 AM   #6
Jeremy
No machining, just shimed the bottom step level. These springs last well and have a low height set up. You can get about any pressure you would like.
Many small block Chevys are using this spring with success in Stock.
At the time I was using these I had a longer than stock valve, I'm not sure how the heights will work out with stock length valves.
Old 08-17-2010, 08:33 AM   #7
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Thumbs up Re: SB Mopar Valve springs?
Comp #926-16 are the ones you want. They take a licking and keep on ticking! They are long lasting and dependable. Jim
Old 08-21-2010, 01:10 PM   #8
mitch kight
Liked 50 Times in 15 Posts
The best spring for a small block mopar is the Comp 904. If the pressure is below 200lbs on the seat, they need to changed. I like around 230 seat with 475 open is good. You really need a pair of Smith lifter's for a mopar so no cam wipes. Lifters are cheap compare to cost of clean up!
mitch kight is offline   Reply With Quote
Old 08-23-2010, 07:45 AM   #9
Chris Hardy
Guest
Posts: n/a
I also like the Howards 98215 "Zero Tolerance 1.25 Drop in springs. They allow enough coil bind clearance to set the seat pressure almost anywhere you would like to run it.
Chris
231-740-5862
Old 08-23-2010, 04:20 PM   #10
Jim Bailey
Liked 584 Times in 94 Posts
Give Don Little a call .......
Jim Bailey is offline   Reply With Quote
