Old 08-19-2010, 12:34 PM   #21
Bryan Worner
Liked 535 Times in 86 Posts
Default Re: engine combination
Originally Posted by Chuck Beach View Post
135 4442 GT/FA Sid Bonnecarrere, Gray LA, '70 Duster 10.121 11.10 -0.979
As I read it Chuck, the old Top Stock motor is the one he was running in GT/FA! Now he is putting in the new Drag Pac motor! Big difference.
3055 lbs to run F!!! Thats less then my minimum to run E and it's more Cubes with a bigger throttle body!! Who rates these things.........Stevie Wonder?
Bryan Worner is offline   Reply With Quote
Old 08-19-2010, 12:37 PM   #22
Chuck Beach
Chuck Beach's Avatar
Liked 58 Times in 13 Posts
Send a message via AIM to Chuck Beach
Stevie Wonder? quote
My misunderstanding, when I talked to Jeff last year at Indy, I thought that was the new 360 rated at 275 .... yea, it should be fast ............................... they are rated by the CEO of government motors ... oh yea, same guy ..
Chuck Beach
3340 STK
Chuck Beach is offline   Reply With Quote
Old 08-19-2010, 02:26 PM   #23
Ed Wright
Ed Wright's Avatar
Guess I need to order a new Dodge truck Oh, wait. Can't run truck engines in cars in GT. Still, I'd like that tall manifold, aluminium heads with those big valves & ports, oh and that 1000 cfm throttle body in my new truck.
Whoever at NHRA that bought that hp rating needs help.
Need to move Wesley to Glendora. Things would get more real.
Can't blame MOPAR for trying, but whoever at NHRA bought into that makes me wonder what they are thinking.
Ed Wright 4156 SS/JA
Old 08-19-2010, 02:30 PM   #24
gmeyer
Liked 35 Times in 16 Posts
That motor came in a DP car. I have one, still intact. If I were building a SS DP, I would start with a wreck sorta like Conutry Dog does because you are going to modify them so much, it would be a lot cheaper. With the 360, it is a natural SS/JA car. I ran mine in SS/KA cause I'm fat. We got a new 360 for this year for the Duster in GT that Kevin is gonna drive. Should be on the dyno Friday. We will also freshen the old motor which is a Top Stock motor that I recycled into GT cause I'm a green kinda guy. And I guess all them Cobalts and Cavalieres don't have hand picked, underfactored, crate motors? I love you guys.
Jeff,
What truck (year and model) did this motor come in with Part # P5153847 al. heads on it.
just curouis
gmeyer is offline   Reply With Quote
Old 08-19-2010, 03:58 PM   #25
Jeff Teuton
Liked 325 Times in 50 Posts
It is a2009 motor. It evolved from 1993 truck to the 1998 R/T which had R/T heads and a single plane manifold, then both the stock heads and the r/t heads disappeared and the motor resurfaced in 2009 with the alm heads. The number you quoted is the casting number, but the part number for the heads is P5155285 for stock and the number you quoted is legal for ss. Part # & casting number is same for ss. I have both heads in stock if you are interested.
Jeff Teuton 4022 STK
Old 08-19-2010, 04:04 PM   #26
Jeff Teuton
Bryan, the Top Stock motor was converted to DP by cutting the dome off the piston, putting up the runners, putting holes in the runners for injectors, getting the cc's right. The problem is the Top Stock motor had a 580 lift cam and hydraulic rollers. That is what it still has. Ran a fastest last year of 9.85 @ Silver Dollar in good air in GT/FA. The dp motor was sorta based off that motor in T/STK. See, it was stock all the way. In the Top Stock configuration it ran a fastest of 9.52 @ 138 @ 2880 lbs with an 850 Q/F carb when it was fresh. The last run it made last year my son Joey lost Myron P. in Baton Rouge @ 9.67 @ 137. We have run that motor in various configurations since 2002. For SS, we also had to remove the plastic hood with the scoop that was worth at least .06.
Old 08-19-2010, 04:19 PM   #27
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
Ed.......Need to move Wesley to Glendora. Things would get more real.
That will never happen with Danny there, Thats why he dont do Nationals. He sure would fix things, I have no doubt.
Bob Pagano A/SA
Old 08-19-2010, 07:30 PM   #28
Bryan Worner
Jeff, is that the motor that was in the Duster in Atlanta running GT/FA? I ran against that car in Class Elims.
Old 08-19-2010, 07:43 PM   #29
Jeff Teuton
That was it. We had a different driver and were having a little trouble getting a handle on it there. It ran 10 teens recently @ No Problem S/SS combo. We pulled it out. It was obviously needy. Fresh now as a backup to the new motor. Probably about time for a new set of pistons after this soup-up.
Old 08-20-2010, 08:10 AM   #30
Ed Wright
Ed Wright's Avatar
Yeah, I know. Too bad. Doubt Wesley would want to live out there anyway.
