Old 09-22-2010, 06:24 PM   #1
Robert Swartz
Robert Swartz's Avatar
Default 70-81 F-bodies Moroso front springs?
I've read numerous things regarding this and still am not sure what direction to take. I've had a couple people recommend to go with the lightest spring available. For the 70-81 F-body, the only listing I have is the (per Jegs) 710-47180 at 1840-1910 lbs/212 lbs/in. The other two listings for this body style are heavier springs.
Just asking, are the springs available for the Camaro/Firebird what needs to be used? Or, can I use a spring for a different application, ie; 79 Malibu, earlier model Camaro/Nova? Would appreciate any insight anyone is willing to offer me on this one. Anybody running these cars have a specific recommendation they'd be willing to share with me?
The car is a 1979 Firebird T/A, being built to run IHRA crate motor stock. These cars are nose heavy. I'm not going to rebuild the front end immediately. I'm going to do the front sub by adding aluminum body bushings. I also have CE 3 way adjustable shocks for the front end. Also going to swap out the front calipers for a set of aluminum Wilwood replacements for a little weight savings. Not an optimum set up but a stopgap measure to attempt to get this car on track, perhaps early next year.
Robert Swartz - Swartz & Lane 66 Chevy II Pro
95 Achieva EF/SA, 78 Mustang II U/SA (work in progress) #354 stock
Robert Swartz is offline   Reply With Quote
Old 09-22-2010, 07:04 PM   #2
CrateCamaro
CrateCamaro's Avatar
Liked 19 Times in 7 Posts
Default Re: 70-81 F-bodies Moroso front springs?
47180 is a big block spring. It might be the lightest spring but I bet its super tall. Im thinking that a 78 Malibu spring will work diameter wise, something like PN 47130. A 78 and up malibu uses a 4in inside diameter spring.
Tony Valerio 1968 Camaro
1700 IHRA H/CM
1701 NHRA SS/?A
Old 09-22-2010, 07:35 PM   #3
jasondearduff
here is what i did with my 71 camaro. i bought 6 cyl springs cut a coil off it reacted good and good wheel stands but this was with a bigger tire, not sure if it would work with a stock eliminator tire?
jasondearduff is offline   Reply With Quote
Old 09-22-2010, 08:17 PM   #4
gsa612
gsa612's Avatar
Liked 280 Times in 139 Posts
I used moroso#47175 springs cut 3/4 off on the pass. side 1/2 on drivers on my 71 camaro big block stocker. Have 5 in. travel, leave them settle a few days, its always a crapshoot with springs but it shoud be close.Hope this helps . John
Old 09-22-2010, 09:56 PM   #5
Dave Ribeiro
Liked 56 Times in 27 Posts
Wink Re: 70-81 F-bodies Moroso front springs?
Robert,
I have some new -never used front Moroso springs for 70-81 Firebird,
they have been setting in the garage for years ... If you are interested ,
$ 40 plus shipping ....
Dave Ribeiro 1033 STK
Old 09-23-2010, 05:04 AM   #6
Robert Swartz
Originally Posted by Dave Ribeiro View Post
Robert,
Dave, you have a PM.
Thanks to all for your responces.
Robert Swartz
Old 09-23-2010, 09:15 AM   #7
ron mattson
Liked 69 Times in 32 Posts
just did this last night, 47175 spring 1 coil cut off 3500lb stocker with bowtie block sits
perfect, just be careful we cut 1/2 coil off car sat 2in high next 1/2 coil off lowered it a lot.
i would start with 3/4 coil off and see where you are.
Ron Mattson 5015 STK
ron mattson is offline   Reply With Quote
