Go Back   CLASS RACER FORUM > Class Racer Forums > Competition Tech
Old 12-26-2009, 05:11 PM   #1
rod
Liked 20 Times in 15 Posts
Default holley bowl gaskets ?
time to stock up on bowl gaskets for the new season.
so, i find red ones, brown ones, black ones and blue ones plus even white plastic ones [i have used the white plastic bowl screw washer gaskets with good success, but never used them for the jet block/bowl]].
which are best and last longest [ie reusable]?
thanks rod
rod is offline   Reply With Quote
Old 02-20-2010, 08:49 AM   #2
sg1586
Default Re: holley bowl gaskets ?
Rod, I have used the red,black,and the blue one as long as there "non-stick" and seem to be fine....I run race gas so alky may be different....I really don't like the plastic bowel screw gaskets as I have striped a bowl screw to try to get it to stop leaking...The thick washers seem to work better for me as they have some "sqush" and keep things tight and no leaks.......And thats IMO
sg1586 is offline   Reply With Quote
Old 02-25-2010, 09:33 AM   #3
SCOTT SST2871
I use the blue ones and run alky,ive used them over and over
good luck scott
SCOTT SST2871 is offline   Reply With Quote
Old 09-23-2010, 05:09 PM   #4
Burner
Do not like the red ones, they always seem to stick, the blue one work the best for me.
Burner is offline   Reply With Quote
Old 09-27-2010, 03:21 PM   #5
NORMAN BARNARD
Liked 2 Times in 2 Posts
Doesn't matter if you use red, blue, yellow,brown or pink always spray them with wd-40 and they "will not stick". On the nylon bowl screws apply a little wheel bearing grease before assemblying to the bowl screw.
NORMAN BARNARD is offline   Reply With Quote
Old 09-27-2010, 08:13 PM   #6
Tim H
Tim H's Avatar
Liked 482 Times in 159 Posts
Had a Barry Grant Kit in my hands today and noticed the gaskets were red. FYI.
Tim H is online now   Reply With Quote
Old 09-30-2010, 01:01 AM   #7
Adger Smith
Liked 880 Times in 311 Posts
Hit'em with a little non stick "PAM"
Adger Smith (Former SS)
Old 10-11-2010, 07:18 AM   #8
Dragsinger
Liked 99 Times in 60 Posts
BLP, [Bo Laws Products] is a very good source for all Holley parts. They have a green gasket that work well and is available in bulk pricing.
Larry Woodfin 471W
