Liked 7 Times in 6 Posts
I get about 20 runs out of a set of plugs and then misfiring starts to happen. Usually it starts above 4,000 rpm. When this happens, I replace the plugs and it's perfect for another 19-25 runs. This has been a problem for me with different engine combos and ignitions. I have resisted spending the cash it takes to buy a 7AL, but do I have a choice?
This is a foot brake bracket car, restricted a little to run low 10.0's. Current engine is a 427 BBC, 13.5:1, Chevy OC aluminum head, HEI with performance module and MSD coil. Timing is locked at 39 and retards to about 36. Plugs are currently NGK B5ES, I've tried B7's and B9's. Over the years I've used MSD 6 stuff, with and without crank trigger, HEI's and Accel dual points. I've used lots of plug brands and racing gasses. Different carbs, intakes, compression ratios etc. I've been lucky this year because it's happened with enough time for me to do a quick plug change and it hasn't cost me a race yet. I can't deal with this anymore. Do I need to just shell out the beans for a 7 series? |
Buy a 7AL.
Liked 1,909 Times in 427 Posts
An HEI is simply never going to be reliable above 5500 RPM, maybe lower, depending on parts and application. It may run to 6500 for a while. The best we've ever been able to do was 6500 for a while with an MSD module and coil, and a new GM pick up coil. You may find one in a dozen or so applications that people get away with. There's a difference between something someone is lucky enough to get away with and something that is reliable enough to race trouble free.
We run the same plugs all year with a 7 AL-3, a Pro Power HVC coil, an MSD distributor, and Moroso wires. I use Champion RC12YC plugs, and VP C-12 gas. We put that ignition system on 4 years ago to replace a bunch of Mallory stuff, I think we put a cap and rotor on it last year. We put plugs in it when they look like they're starting to get too much residue on them from the additives.
Alan Roehrich 212A G/S |
#4 | |
Can I use the HEI for coil and trigger? |
Do not use anything from the HEI system. Please, remember that HEI was designed for a time when 5500 RPM was high RPM, and 300HP was a lot.
Buy an MSD distributor and put the Comp poly gear on it, all your distributor problems will go away. It plugs straight in to your box, no place to have a problem. The MSD 7AL 3 simply has all of the rev limiter features built in. It has a burnout limiter, a stage limiter, and a high side limiter. If you do not need all of that, then consider a different 7AL. Get the Pro Power HVC coil, it works great with the 7 series ignitions, without problems. I've been through all of that. We fought the "mix and match" ignition BS for a year, then we took all of the crap off, put a complete MSD system on, and we do not worry about ignition problems anymore. Put in a matched integrated system one time, and be done with it all. No compatibility issues, no guessing, just race. It's a great feeling.
#6 | |
Chad Rhodes 2113 I/SA |
#7 | |
I'm not thrilled with the Comp gear idea. I had one in my hand a while back and it made me shiver. Then I called Chris at Comp and he told me they have had some failures with it, but not many. I sent it back to Jegs. I filed a little groove in the HEI housing to keep the gear lubricated. I know the MSD's have an O ring to seal up the distributor. Do you guys modify that at all? |
Nope, I don't modify anything. And the Comp gear in the car has been in the car for at least 3 years. We carry a spare, but have never used it.
If you're convinced that you're never going to need 3 RPM limiters, then don't buy the 7 AL-3. We've got the same Moroso 40 series wires on the car we've had on for 2-3 years. MSD wires would be fine as well.
Liked 880 Times in 311 Posts
At the RPM you are running a 6 AL with the big coil will save you money and do the job. Then there are no questions about No-E or footbrake classes. I have had the best all around luck with the -8 plugs w/ extended tips in BB engines. (when properly jetted) Remember the smaller the number in those plugs the hotter the plug. You could be just burning them up with chamber heat or killing them with heat caused Pre ignition/detonation. A cooler plug is always better to keep from glowing and causing pre ignition.
Adger Smith (Former SS) |
#10 | |
