Old 10-11-2010, 09:20 AM   #1
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
Default Looking for your input on..........
How to set up a "stock type". '68-'72 GM "A" body rear suspension, to take the abuses of low 10.- to high 9.- sec. 3500 lb. drag race car?
Have you been there, done that?
I am having issues with "stock" frame, connecting points, "moving (not broke yet) around....
Tell me about bracing, or anything, short of putting in a complete ladder bar suspension......
I have the factory upper to lower control arm braces.
Control arms (upper, and lower) are all adjustable (lowers have "relocation brackets", at the rear). All ends are "Himes type" except the uppers at the rear, are poly...
Detailed, pictures would be great.... TIA
Old 10-11-2010, 11:47 AM   #2
Greg Barsamian
Liked 427 Times in 97 Posts
Default Re: Looking for your input on..........
Contact Alf Wiebe @ wiebemetal@shaw.co
Old 10-13-2010, 08:42 AM   #3
Jim Kaekel
Liked 535 Times in 110 Posts
Bob: H&R Parts 'n' Stuff offers a bracket that reinforces the front lower control arm mounting point. I presume you have a reinforcement bar that joins the front lower control arm to the front upper control arm. I have found that bar to be very important. I had one that was slotted (Edelbrock) and noticed that there was movement in it due to the slots. Needless to say I replaced it with a non-slotted brace from Dick Miller.
Jim Kaekel 3836 STK
Old 10-13-2010, 10:16 AM   #4
TimKGillespie
Liked 38 Times in 9 Posts
Is that shaw.com or shaw.co?
TimKGillespie is offline   Reply With Quote
Old 10-13-2010, 06:30 PM   #5
rallye bob
rallye bob's Avatar
Jim;
I am running the stock (stamped steel) reinforcement brkt. that ties the uppers, and lowers, together. I may go to a tubular (adjustable) unit.....
I will check out the H&R Parts 'n' Stuff bracket. I am running their bolt on anti-roll bar, and love it....
Old 10-13-2010, 07:56 PM   #6
Dave Jung
Dave Jung's Avatar
Liked 5 Times in 5 Posts
shaw.ca
6535 stk
81 Malibu K/SA
Dave Jung is offline   Reply With Quote
