Old 10-19-2010, 10:39 PM   #11
dartman
dartman's Avatar
Liked 68 Times in 41 Posts
Default Re: Staging beam and starting line ?????
http://www.portatree.com/media/ccp0/...-StartLine.pdf
http://www.portatree.com/media/ccp0/...lloutWheel.pdf
this may be helpful
1231 FS/D Drag Pak
1231 E/SA 71 Demon
Kelly MacKay
dartman is offline   Reply With Quote
Old 10-19-2010, 11:16 PM   #12
Jeff Foster
We have changed the height of the tree to 95" from ground to center of pre stage bulb about 3 years ago. Also guard beam was changed to 13.5 inches 3 years ago.
Jeff Foster is offline   Reply With Quote
Old 10-20-2010, 12:10 AM   #13
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
Is there a fixed # for roll out?
Former NHRA #1945
Former IHRA #1945
T/SA
Old 10-20-2010, 08:15 AM   #14
cad
cad's Avatar
Liked 93 Times in 52 Posts
Originally Posted by dartman View Post
Right or wrong, that is exactly how our track does it!
Clark
Old 10-20-2010, 10:41 AM   #15
racerhead
Another noteworthy point is the beam itself. The beam is about 1/4" wide, and the beam is two inches up off the track when measuring to the top of the beam. It's the staging beam height that determines the rollout.
I've seen good racers confuse the pre-stage beam as part of the rollout equation...it's not. The prestage beam is there for location purpose only...to let you know you are within inches of the stage beam.
It's a valuable lesson to take a tire to the starting line and roll it into the beam...and to see how small a distance that last 1/4" is from not staged to staged. It makes you realize how carefully you must move those last few bumps in if you are going to cut consistent lights.
Bruce Deveau
racerhead is offline   Reply With Quote
