Liked 20 Times in 15 Posts
is it possible that an MSD 7 can check out good [by MSD] and fire, but still not work correctly?
my car has lost almost 3/4 of a second. the MSD is the only thing i have not changed. the car still rpms the same, just no power. i have changed or checked a lot of parts. no difference. just slow! thoughts? thanks rod in AZ |
Liked 11 Times in 8 Posts
I've seen the polarity of pickups magically reverse. This typically retards the ignition timing. Joe
Joe Buchanan SS/BX 3117 |
Liked 280 Times in 139 Posts
If your running a crank trigger check the wires going to it, if they are reversed the car will run, start, etc. but you will only have about half the total timing. Just went thru this on a buddys car. gsa612
would look at borrowing another coil and making a pass with it.....especially with one of the newer style MSD coils
Liked 334 Times in 181 Posts
As far as the coils go check the resistance between the positive coil terminal and the neg coil terminal resistance should be less than about .016 or so then check the resistance between the positive coil terminal and the coil tower that should be about 30 ohms---if either of those numbers are off the coil is bad---if the numbers are close then you have problems elsewhere---also check the air gap at the pick up and make sure that the magnets in the flipper wheel are not loose too as well as the pickup wiring----do you have ANY other wires running in close proximity to the pick up??? Those pick up wires should be shielded you can get some stuff at most electronics stores to do that helps prevent any stray signals from interfering with the signal from the pick up to the MSD box---Comp
Also like GTX said borrow another MSD coil see if that solves the problem---Are you using a MSD 7 that is set up for the correct engine you are using?? By that I mean a 7220 for an 8 cyl engine or a 7224 for a 4??? You cannot use a box for a 8 on a 4 or 6 and vice versa it will not function properly
Liked 551 Times in 215 Posts
I had an MSD 7al 2 in my Firebird Stocker. One day at the track I started to get misfiring over about 6000rpm and the tach was jumping around when it misfired. This engine had a crank trigger and most everything but the MSD box was new. I borrowed my friends identical 7al2 and the car ran perfect...no missing. I sent my box to MSD.....they said they could find nothing wrong with my box. I swapped it back into my car one day at the track....same problem returned...missed badly over 6000 and tach was shutting off when it missed....removed it and reinstalled my friends box same day....no missing. I bought a Digital 6 and matching coil and installed that. That box failed for the person who bought that car and it was no more than 2 years old when it failed. Probably got wet sitting out in the rain from waht I was told....I used to think MSD was the best ignition and boxes either worked or they didn't. I bought an MSD ignition box tester that they sell.......it allows you to fire the box without the engine running......pretty handy for testing a lot of things that are rpm triggered and to see the spark energy at any rpm. If I have a box I am not sure about...I'd replace it and MSD is not the only brand out there...Mallory has a good reputation for reliability.....
If you have an MSD distributer with mag pickup in the distributer your problem could be the small module in the distributer........I have a friend who chased a miss for months and that is what his problem truned out to be.....
Rich Biebel S/C 1479 Stock 147R Last edited by Rich Biebel; 10-22-2010 at 06:02 PM. |
1. i was unaware that there were different boxes for different cylinders. will check that.
2. this chevy has a mallory uniliite for trigger. 3. the tach needle does, in fact, moooove towards 0 when it pops. 4 i have raced this car/engine for 37 years and never had it pop at the top of a gear. it does have an 8K top rpm chip, so it shouldn't be that as 7K is as high as i ever push it. 5. i have 2 different coils i can sub in. will try that also. 6.i am so MAD i could scream !!!!!!!!!!!!!!!!!!!!!!! guys thanks for all the suggestions rod in AZ |
I have several proven MSD coils you can borrow....I am right over new bridge.
John Irving |
#10 | |
Liked 20 Times in 12 Posts
