Old 10-28-2010, 02:59 PM   #1
treessavoy
Liked 4 Times in 4 Posts
Default Block Rust Removal
I have several blocks that were already machined but a thunder storm blew out the back wall of the garage and the humidity caused the blocks to surface rust on all machined surfaces.
Anyone know a good way to clean them up?
JimR
Jim Rountree
Old 10-28-2010, 03:33 PM   #2
FED 387
Liked 333 Times in 180 Posts
Default Re: Block Rust Removal
ever try soda blasting??? Seems to work with no metal removal---you blast it, wash it off with water then blow dry to remove water and spray Blaster or a marine fogger to protect from rusting--Comp 387
Old 10-28-2010, 03:49 PM   #3
FED 387
another product is
called Rust lick----Comp
Old 10-28-2010, 05:06 PM   #4
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Jim, You can try getting a bottle of metal prep solution from ypur local body supply house......It's a very dilute acid made for prepping bare metal before bodywork. ...I've used it to clean cylinder walls that had light rust. .........just be sure to neutralize the surfaces with clear water and blow dry before oiling them down
Old 10-28-2010, 05:16 PM   #5
Dgal
We have used vinegar for rust on guns and tools. Works pretty well, plus it should kill any yeast infection.
Don
Dgal is offline   Reply With Quote
Old 10-29-2010, 07:48 PM   #6
Adger Smith
Liked 880 Times in 311 Posts
Try Evapo-Rust... Works good at my shop and I've been told other shops use it.
Adger Smith (Former SS)
Old 10-30-2010, 09:43 AM   #7
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
Try CLR.....
Old 10-30-2010, 10:29 AM   #8
Joe Schweigert
Joe Schweigert's Avatar
Liked 19 Times in 8 Posts
CLR works great my need several applications it's available at the Home Depot and Lowes
Joe Schweigert 751 SS
Joe Schweigert is offline   Reply With Quote
Old 10-30-2010, 09:50 PM   #9
John Dinkel
Liked 263 Times in 68 Posts
I have used scotch brite pads and WD-40.
John Dinkel 3295 STK
John Dinkel is offline   Reply With Quote
Old 11-01-2010, 02:21 PM   #10
treessavoy
Thanks Guys,
I used everybody's suggestions and the block melted.....lol!
Thanks for the help,
JimR
Jim Rountree
