Old 11-10-2010, 09:02 PM   #1
astikhossw
astikhossw's Avatar
Liked 20 Times in 9 Posts
Default cam timing question
What is the perferred method for advancing the cam timing, on the crank or the cam sprocket or both.
astikhossw is offline   Reply With Quote
Old 11-10-2010, 09:59 PM   #2
buzzinhalfdozen
Liked 11 Times in 8 Posts
Default Re: cam timing question
Depends on what you have to work with I use the multi key way crank gear on my motor , really not much choice for me. Can usally get within degree or less of where I want it. Joe
Joe Buchanan SS/BX 3117
Old 11-11-2010, 10:17 AM   #3
astikhossw
astikhossw's Avatar
Joe' when i bought my little motor those nascar guys offset ground a dowel pin and had a 108 cam center line cam at 98 center line with max on the crank and alot on the cam.i gues that is the only way to do it on the ford v-6.
Old 11-11-2010, 01:41 PM   #4
richie 2
Liked 205 Times in 93 Posts
how much do you have to move it?
richie 2 is online now   Reply With Quote
Old 11-11-2010, 01:56 PM   #5
buzzinhalfdozen
Don't like the offset pins it weakens them. I've got a couple crk. gears with 8 keyways so can move it alot. I've double pinned cam gear, lots of valve spring pressure makes it a requirement. Joe
Old 11-11-2010, 04:53 PM   #6
astikhossw
astikhossw's Avatar
So is that something any machine shop can do,are did you buy them that way.Also i have lost our ford v-6 suppliers in Colorado's name and phone number do you still have it.
Old 11-11-2010, 06:37 PM   #7
buzzinhalfdozen
Leonard Vansholtz 719-687-9827 He should be able to hook you up. Joe
