Old 11-17-2010, 09:53 PM   #11
Stewart Way
Liked 70 Times in 22 Posts
Default Re: 5.7 Hemi
In section 8 of S and SS it states Aftermarket starters, in stock location, permitted. Guess that would mean for stock starters too. But it would appear that this rule is in every SS class, even the SS/?X classes. At the start of each SS class it says that the rules are the same as the previous SS class with the following exceptions. Since there is no exeception for starter location in SS class or any following class it would require that the starter be in the stock location. .At least thats my read
Stewart Way 2424 SS
Old 11-17-2010, 11:54 PM   #12
Peter Ash
Peter Ash's Avatar
The Drag Pak cars use a LHS starter with the 727/904.
Peter Ash is offline   Reply With Quote
Old 11-18-2010, 12:05 AM   #13
Adger Smith
Liked 880 Times in 311 Posts
Peter, is that the left facing the engine or left in the drivers seat??? :~) HA!
Stewart,
You have a PM.
Adger Smith (Former SS)
Old 11-18-2010, 12:26 PM   #14
Peter Ash
Peter Ash's Avatar
Stewart,
You have a PM.
It would be the car's left side.
Old 11-19-2010, 11:17 AM   #15
Jeff Teuton
Liked 325 Times in 50 Posts
The starter in the specs for all drag packs is for mounting on the driver side. The 2008 prototypes had this. ATI makes a starter, as does RobbMc (which is the Mopar part #). Bolts up to a 904/727/ or bell housings are available for both sides to service the drag packs and street challengers.
Jeff Teuton 4022 STK
Old 11-19-2010, 11:59 AM   #16
Stewart Way
Thanks Jeff. Hope your getting around well. I have asked NHRA to clafify this question and the official I talked to mentioned that he had seen this thread so he will likely see your response as he researches the answer. Initial response was for drivers side but more checking was required. I also asked about Hyd throwout bearing with a biondo button to have the same setup a transbrake car has (for SS). He did not say Hyd was illegal but again he will look into it and get back to me.
Jeff, got an extra intake and TB sitting around for a DP?
Stewart Way 2424 SS
