Old 11-20-2010, 08:26 PM   #1
joe176
joe176's Avatar
Liked 41 Times in 9 Posts
Default HP Rating....F Body vs FWD Conversion Cars
Alot of conversation takes place about how the F body camaro / firebird platform should be separate on the hp rating because it's at a performance disadvantage vs the FWD Cobalts/Cavaliers. I have alot of data that proves this right but not to the extreme that most racers I hear talking about say it is.
My 1985 Camaro ran well and I had my heart and soul into that car....it was a top qualifier/ record setting car. It had the same efi engine combination in it from the start of the 2006 season until I decided to switch to a cavalier at the Dutch Classic 2009. I have now run the cavalier for one full season and pretty much can say it is sorted out. The reason I wanted to make the change was more technology than love of the car per say. The new car has all the latest innovations to make it easier to work on. Dash comes out...one piece headers.....coil over front springs/struts...equal length four link.....so on and so forth.
So if you took a complete drivetrain out of a camaro and installed everything and I mean everything in a FWD conversion car.....what would it be worth ??
I know because I did it......I took the engine (efi intake to charlie's oil pan), injectors, trans,converter, complete msd ignition including the coil, big stuff computer, complete ring/pinion/center section, same M/T radials, shifter w/air kit, duplicated the Aeromotive fuel system, and the same 16 volt batteries. Out of the box at a track rental first time out at maple grove/dutch classic 09 the car in GT/FA went 9.81@ 133 mph four times in a row at race weight. .....which will be my term for fast runs with radial.
This is some of the comparable data that I have come up with in 5 years of running this particular combination.
Camaro----------------Camaro---------------Cavalier-----------------Cavalier
GT/HA-------------------GT/HA-----------------GT/FA-------------------GT/FA
Cecil 8/08-------------Atco 10/08---------Lebanon 7/10----------Etown 9/10
1.361---------------------1.336------------------1.270---------------------1.274
4.055---------------------4.006------------------3.901---------------------3.904
6.373---------------------6.294------------------6.148---------------------6.151
105.49........................106.81.............. ......109.86........................108.84
8.384..........................8.286.............. .........8.104..........................8.106
10.091........................9.988............... ........9.769..........................9.773
131.81........................132.27.............. ......134.79........................134.00
77.6 degrees.............74.9.......................... 69.8.............................68.8
51.4 %........................29.0 %.....................52.2%....................... ...51.1 %
29.99..........................30.07.............. ..........29.50...........................29.79
1573'..........................1291'.............. ..........1534'............................1112'
wind 15 degrees......wind 291...................wind 90........................wind 90
6-8 mph......................0-3 mph....................3-6 mph.......................10-11 mph
race weight................race weight..............race weight...................race weight
.................................................. ................ ..-275 lbs lighter.............-275 lbs. lighter
-1.259 old index........-1.362 old index.......-1.331 old index..........-1.327 old index
these are just a small sample of what I have found....these runs with the cavalier are after adjusting the converter, fuel map, shift points, leave rpm and rear gear.This car weighs 275 lbs lighter than the camaro at race weight....I have been comparing data for the latter half of this season for my own curiosity and I feel that the advantage is only 3-5 hundreths at the most....not a tenth to two tenths which is what I've heard in the past.
Joe Franco SS176
joe176 is offline   Reply With Quote
Old 11-20-2010, 09:11 PM   #2
SS Engine Guy
Default Re: HP Rating....F Body vs FWD Conversion Cars
Joe, your estimate seems accurate based on the difference in quarter and eight being in the 2.2 - 2.3 tenths faster. The old rule of 100 lbs being worth a tenth is not nearly as accurate as some originally thought the closer the racecar is to optimum. With a weight difference of 275 lbs. according to the old theory the car should be 2.75 tenths quicker and it is not. I know that your older Camaro was a pretty efficient piece and you have got the new car on the right track. HP is one thing, being able to use it optimally is another. You, being a pretty capable tuner, both engine and chassis makes this a valid (in my opinion) comparison.
I agree with you that the ease of being able to work on the new car easier is a definite advantage. Especially when trying different back to back comparisons.
I know what some are getting at about the fwd conversions. Being that the drivetrain is moved farther back in some cases. However, I never heard or saw you have any traction problems in the blue camaro.
SS Engine Guy is offline   Reply With Quote
Old 11-20-2010, 09:45 PM   #3
Ed Wright
Ed Wright's Avatar
Very interesting! Thanks for sharing, Joe.
Btw, 100 lbs = .07 et in my car. My old N/S '56 Chevy Jr Stocker 100 lbs was more than a tenth. I was talking to Alan Patterson & Jim Hayter about this very thing once. Jim said most sbc Comp cars change about 5 hundredths per 100 lbs. I think, traction being equal, it's related more to hp. Just my guess.
Ed Wright 4156 SS/JA
Old 11-21-2010, 08:11 AM   #4
Lee Valentine
Liked 319 Times in 68 Posts
Talking Re: HP Rating....F Body vs FWD Conversion Cars
Does Angelo know about this!
Lee Valentine 1661 STK
Old 11-21-2010, 01:28 PM   #5
joe176
joe176's Avatar
Yes he does Lee.
Joe Franco SS176
Old 11-21-2010, 01:59 PM   #6
Hagen Gary
Liked 34 Times in 10 Posts
Thanks for your time to post and honesty about this situation.
Its my opinion that if NHRA is going to allow two totally different sets of rules for FWD Conversions and any RWD(not just f body) cars then why not add 2% of rated hp to the FWD conversion. That would equate to that 3-5 your talking about.
Hagen Gary is offline   Reply With Quote
Old 11-21-2010, 02:06 PM   #7
stefan callender
stefan callender's Avatar
Liked 2 Times in 2 Posts
Joe, also remember that your Camaro was built in the 1990's also didnt have all the same technology that your 2000's Cavalier has. An unequal four link, vs a equal length four link. How much is that worth?
Has anyone ever took a 82-92 F-body and transform their entire drivetrain and put it into a next generation F-body?? How much was that worth??
Old 11-21-2010, 02:53 PM   #8
Hagen Gary
Stefan, Are you talking about a 2010?
Joe, you get to weigh 275 lbs lighter and only lose .25 of index, right? Couple that with extensive front and rear suspension and floor mods, engine/firewall and driver location, all if which RWD cars are not allowed, and 3-5 is all you get? I'm not saying your compleatly wrong, but maybe if you put in the same amount of time with this car as the last, you might see its worth more.
I know what the rules are and I chose my car according to them. I'm just asking that if we are going to make adjustments, then lets fix the obvious inequalities, or let me move my firewall and floor so I can make suspension upgrades front and rear.
Old 11-21-2010, 03:21 PM   #9
Ed Wright
Ed Wright's Avatar
275lbs out of my car wouldn't be worth any more than that.
Old 11-21-2010, 03:55 PM   #10
joe176
joe176's Avatar
Hagen.....I do not need anymore time sorting this out...it's not rocket science when you swap everything over to a new car and run the numbers this car runs....it is what it is...I've been doing this long enough to know a few minor tweaks here or there depending on air and track conditions is all you can do when you roll into a race. As far as the firewall setback.....my camaro had better weight ratio front to rear than this car does..........these cars are nose heavy....not sure what kind of car you run or if you've had experience with both like I have.
Joe Franco SS176
