Old 12-07-2010, 10:26 PM   #41
Jeff Teuton
Liked 325 Times in 50 Posts
Default Re: new hp
We plan on storing #1, and racing #3. If the other guys who are getting No 1 thru 10 want to post, they can tell you who they are. Some very well known names.
Jeff Teuton 4022 STK
Old 12-07-2010, 11:51 PM   #42
The Hawk
The Hawk's Avatar
Liked 249 Times in 109 Posts
Default Re: new hp
With the HP letters being sumitted and granted HP or being turned down,does anyone have an idea what NHRA looks at when making decisions? I know of one V6 FWD FI combo that`s been given back at least 25 HP in a span of about 6 or 7 years to be rated less than a carburated combo and go from being an uncompetitive car to being .40 under the new indexes and doing nothing to the car? I`ve written letters and got nothing,where some have submitted timeslips from a bracket race and received a HP reduction. Not looking for sympathy,just looking for answers to what NHRA looks at.
Lane Weber
Old 12-08-2010, 09:22 AM   #43
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Cool Re: new hp
They dont look at anything.....In case you havent noticed they are blind !
Old 12-08-2010, 09:59 AM   #44
Dan Wilson
Default Re: new hp
A question to Jason.
The cam stayes the same lobe lift.
If the rocker ratio is increased from 1.60 to 1.65 will the valve lift
1. remain the same
2.decrease
3 increase
Dan
Dan Wilson, STK3171, K/SA
Dan Wilson is offline   Reply With Quote
Old 12-08-2010, 11:16 AM   #45
Chad Rhodes
Default Re: new hp
1. remain the same
2.decrease
3 increase
Dan
i know the answer, pick me!!!!!!!!
Chad Rhodes 2113 I/SA
Old 12-08-2010, 11:27 AM   #46
Jason
Liked 8 Times in 5 Posts
Default Re: new hp
1. remain the same
2.decrease
3 increase
Dan
A few questions for Dan.
The specs sent out for your engine in 19?? were what they were. Did the factory technican sending the specs back then know what your engine was built with? Would you like to have a new rocker arm ratio on your engine? If so just call the factory and see if you can get an increase on your engine's rocker arm ratio and cam lift.
I'm sure it would all be readily accepted!
Jason is offline   Reply With Quote
Old 12-08-2010, 01:04 PM   #47
Steve Polhill
Steve Polhill's Avatar
Liked 262 Times in 74 Posts
Default Re: new hp
Originally Posted by ALMACK View Post
That link shows the 1984 T-Bird/Cougar Turbo 2.3 rated @ a NEW 171 HP... ???
That's what is was factored to in April 2009 and is still in effect.....odd
The new HP is 174 the cloumns don't line up.
Steve Polhill
3520 STOCK, COMP
Steve Polhill is offline   Reply With Quote
Old 12-08-2010, 01:51 PM   #48
Crew Chief
Liked 10 Times in 6 Posts
Default Re: new hp
Originally Posted by Jason View Post
You mean the factory sent the wrong specs out originally on both the rocker arm ratio and the cam lift? Yeah....Right!!!!!
The rocker arm ratio was a missprint in the original specs. It should have always read 1.65 to 1.
The cam lift should have remained the same as originally printed as it was not a missprint. The cam lift as originally printed has passed teardown because the engines were built to the old spec using 1.65 rockers.
DP racers got an early christmas present on the new cam lift.
Crew Chief is offline   Reply With Quote
Old 12-08-2010, 02:01 PM   #49
X-TECH MAN
Banned
Talking Re: new hp
A new Chritmas present ! They have recieved Santa's whole North Pole operation already.....LOL.
Old 12-08-2010, 05:07 PM   #50
Jeff Teuton
Default Re: new hp
It's about time we got something. We been pooed on for years. And I am thankful to Santa Clause. I heard Santa also had some special facial creme that removes the Bowtie from the middle of the forehead. It's gonna be a long winter.
