Old 12-11-2010, 01:40 PM   #11
ron mattson
Liked 68 Times in 31 Posts
Default Re: ET Difference with 2.75 low gear
I have tried both 2.75 and 2.91 first gears and the 2.91 makes the car a animal in 60
feet .03-.04 better in sixty ft but hurts et from 60 to 330 it seems like the motor gets
pulled down to much to recover efficiently. i think a higher torque lower rpm engine may
be better suited to this application.
Ron Mattson 5015 STK
ron mattson is offline   Reply With Quote
Old 12-11-2010, 02:26 PM   #12
junior barns
Liked 20 Times in 14 Posts
Which application?
junior barns is offline   Reply With Quote
Old 12-11-2010, 02:50 PM   #13
ron mattson
I have tried it with both 1970 350/290 hp and 1972 350/278 with similar results in
both applications. im thinking if you could get the torque to a higher level between
the converter flash and 1-2 shift rpm it could work.
Old 12-12-2010, 01:24 AM   #14
Tim Ellis
Liked 7 Times in 6 Posts
Smile Re: ET Difference with 2.75 low gear
How about your reaction times, did they get quicker with the low gear set, seeings how you 60 footed better?
Tim Ellis is offline   Reply With Quote
Old 12-12-2010, 02:08 AM   #15
Jeff Lee
Jeff Lee's Avatar
Just think what you could do with a data recorder and a timed ignition retard...
Jeff Lee 7494 D/S '70 AMX
Old 12-12-2010, 07:46 PM   #16
Glenn1066
I have a 65 chevelle 283/230 SS/MA @3390 lbs, changed from 208 glide to light weight 2.75 Turbo, found nothing, changed converters 600 higher, stall still nothing.
Glenn
Glenn1066 is offline   Reply With Quote
Old 12-13-2010, 01:50 AM   #17
J Kuchel
Banned
Question Re: ET Difference with 2.75 low gear
Do you think I would show a gain with a low compression big block Chevy? It is a foot brake car. It's weighs 3300# and has a 2.48 gear in it now. Just looking to better my 60' and 1/8th mile time.
J Kuchel is offline   Reply With Quote
Old 12-13-2010, 03:05 PM   #18
ron mattson
Tim the reaction did get a little quicker as the car really wanted to wheelstand pulling the
wheels up out of the beams not rolling out. Jeff your on to something..Shhhhh...
J Kuchel- the deeper first will definatly help in 60ft, in the 1/8 im not sure most likely
would but a deeper rear gear will help all that if your only going 1/8 mile
Old 12-13-2010, 03:47 PM   #19
bottombulb
About .015 difference in reaction time.
bottombulb is offline   Reply With Quote
Old 12-13-2010, 08:06 PM   #20
Tim Ellis
Thanx for the response guys
