Old 12-22-2010, 09:15 AM   #1
richie 2
Liked 205 Times in 93 Posts
Default F body stockers
whats the trick to get those GM torque/arm cars to wheelstand. some launch pretty high....I need my 327 196:1/PG/transbreak '82 Z-28 to 60' like that...thankyou & enjoy christmas everyone!!!
Old 12-22-2010, 09:33 AM   #2
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Default Re: F body stockers
Horsepower!
Old 12-22-2010, 10:15 AM   #3
Chad Rhodes
Horsepower!
converter, gear and suspension geometry. Although its pretty difficult to make one NOT hook. The first thing i would do is get rid of the glide for a TH-200 or 350. If the car is anywhere close to stock weight its needs more low gear. What rear gear is in it? If you still have the stock 10 bolt get rid of it because it will never go fast with one of those and live to tell the tale
Chad Rhodes 2113 I/SA
Old 12-22-2010, 11:55 AM   #4
richie 2
thanks lads! SJ/327ci w/ FT SRP pistons, ported bowtie heads (202"X160") SS roller cam, VJ & Q-jet, 196:1 PG W/ brake, ATI converter, mosier 9" w/488 gears, 10.5" x 30" hoosier, spour torque arm & coilover rears. complete quay front components & coil springs w/koni struts & delarum bushings....hanging around S/SS pits has produced this combo....and i want it to "GET UP & GO".
Old 12-22-2010, 01:11 PM   #5
Ed Wright
Ed Wright's Avatar
I can't believe you can't keep it off the bumper. You have somethng wrong.
Ed Wright 4156 SS/JA
Old 12-22-2010, 04:48 PM   #6
Tom Goldman
You would need 200# in the FRONT to keep a combination like that off the rear bumper!
It really is hard to keep one of these off the bumper , something is wrong with your shocks ,or converter.
I've had cars in my shop that had the rear suspension tearing out the bolt holes and brackets,and they still launched wheels up!
Old 12-22-2010, 09:43 PM   #7
K Stubbs
Liked 20 Times in 3 Posts
One problem is you do not have enough gear. If you have a SS roller cam, it is large and you will need more rear gear for it to work right, even with the 30 inch tires. The 488 is what most stockers run, not SS.
K Stubbs is offline   Reply With Quote
Old 12-23-2010, 11:01 AM   #8
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
Besides needing more gear what is the stall on your converter ?
Bob Pagano A/SA
