Old 12-23-2010, 10:01 PM   #1
Jason Fuller
Guest
Posts: n/a
Default 1970-1972 Chevelle frame...what will get me bounced?
12
Old 12-23-2010, 10:20 PM   #2
Run to Rund
Liked 54 Times in 27 Posts
Default Re: 1970-1972 Chevelle frame...what will get me bounced?
If your year had F35 HD frame available as an option, it is the convertible frame, adds about 40 lb but will give you a tremendous increase in stiffness.
Old 12-23-2010, 10:41 PM   #3
Jason Fuller
Guest
Posts: n/a
secret :0
Old 12-23-2010, 11:00 PM   #4
FED 387
Liked 333 Times in 180 Posts
Any GM midsize convertible frame (buick/cutlass/lemans/gto) of the same years had boxed frames extra support in the rear kick up area etc.---all the others were C frames the Conv also had more body fastening points for frame to body stiffining
Old 12-23-2010, 11:24 PM   #5
Jason Fuller
Guest
Posts: n/a
secret :0
Old 12-23-2010, 11:30 PM   #6
Greg Reimer 7376
Liked 719 Times in 220 Posts
Cool Re: 1970-1972 Chevelle frame...what will get me bounced?
The El Camino and the wagon use the same wheelbase frame,but the wagon is a C cross section.I seem to remember some El Caminos have a boxed frame.The 4 door, the wagon,and the EC are a longer wheelbase than the 2 dr.hardtop and the convertible.There's just enough differences to really screw you up if you don't catch them!The 68-72 2 dr hardtop all use the same frame, so there are 5 years of similarities here.
Old 12-23-2010, 11:50 PM   #7
Jason Fuller
Guest
Posts: n/a
Greg, thank you...
Jason
Old 12-23-2010, 11:52 PM   #8
FED 387
Camino has the boxed frame ---WAGONS DO NOT they have the C frame
Old 12-23-2010, 11:55 PM   #9
Jason Fuller
Guest
Posts: n/a
secret :0
Old 12-24-2010, 12:09 AM   #10
FED 387
2011 NHRA rulebook section 10A page 8 says frame must be stock for body used so I'll check to see if GM had a HD frame for the 2 door HT yers is a HT correct???
