#11 |
Banned
Liked 235 Times in 110 Posts
#12 |
Liked 32 Times in 19 Posts
Too many motor types and specs to check. It would be totally counter to religion of Stock and SS with the motors having "specs" but Mod production only type motors 2 barrel, 4 barrell, 2/4 or injection and lb/cubic inch would remove many opportunities to Cheat. Pump them at the end of the track by the scales and go home.
No more cam cheating, crank cheating, rod cheating, piston cheating. No I dont like it but it would cure a lot. |
#13 |
Liked 112 Times in 31 Posts
Yeah of course you're right Dick. It would cure a lot. Mostly it would cure many people from the addiction they now have (class racing) and give them time to persue another endeavour. I think you're over-estimating the number of people that can actually afford to build a competitive comp style engine.
Jerry |
#14 |
All racers see the "issues" from THEIR prospective. What car they own affects their stand. What brand they support, what dealers give them parts etc etc.
We have all been tied to the "factory Spec" ideas so long any major leveling of the fields by common specs or parts is FOREIGN and OFFENSIVE. Look at sports car club racing. (my limited knowledge). One motor, one class. Bigger motor another class. Sealed motors to keep costs down. Different Brands in separate classes. Many months ago Jim Boburka and myself and others suggested Common specs for three brands with common wt cars. All based on Current available over the counter parts. A FOREIGN idea if you own a car to sell, or only know one motor or stuck in your ways. Much like super modified with Limited flat top piston, head combinations. Cheaper, over the counter and use in body styles you may already have in the garage. When started could be divided by wts into multiple classes if needed. Win with a tune up, traction set up, tire or gear choices. DRIVING SKILL. Not bogus HP ratings, Bogus specs, Ignored combinations from archives. |
#15 | |
Liked 100 Times in 45 Posts
independent brand cars.:>)
Former NHRA #1945 Former IHRA #1945 T/SA |
#16 | |
Gary Hampton '86 Z24,173 V6 CF/S #5824 (#78 in 2021) |
#17 | |
Banned
#18 | |
Liked 7,793 Times in 1,746 Posts
#19 |
Ed, What no AMC 350 blocks, or motors, or heads. The classes I listed were a starter which could be adapted to 90% of current racers. Others could run as is in their classes if wanted or if the 1 % of AMC racers wished I am sure a similar AMC type motor could be created with their input...Remember the goal of the topic was the best for the CLASSES not the best for ED or AMC or Dick BUtler or any one faction. It was with the overall group or classes as a goal. Jeff or other great running AMC guys could adapt.
Billy, if we could find a BIG corp like JEGS to push it and who would earn money from production of the motors it would FILL the pits with cars. Last edited by Dick Butler; 12-26-2010 at 03:14 PM. |
#20 |
Liked 5 Times in 3 Posts
Nhra has lost the handle along time ago on Stock Eliminator rules enforcement,as the rules changed camshafts,springs,it was increasingly easier for racers and nhra to look the other way accordingly.Depending on what era you grew into, 60's,70's,80's,etc I think has a direct influence on what and how you build your car, integrity now has been compromised for winning at any cost. Cost of racing has skyrocked more so for the technology that has trickled down through to Stock, but what has been lost is the definition of our class, once known as a entry level class, now has become more expensive than what it took to run a Pro Stock in the 70's. Were all guilty for the sake of going faster we have excepted this racing and its rules structure and ultimately its demize because INTEGRITY, HONESTY,and RULES, have been thrown out the window.I once changed classes from Super/Stock back to Stock because the cylinder head rule changed and spending $5000 and more to keep up performance was out of the question now I find myself again at a crossroad,$50,000 and up Stockers just doesnt make sense.Acid dipped bodies,acid dipped cylinder heads,$4000 headers,55mm camshafts,light wt valves,spools, axles, brakes, transmissions,suspension pieces front and back, and racepak computers,have all been overlooked and excepted as the normal thing to due. The Stock Eliminator world has a ever changing horizon but a $100,000 race car, trailer,truck,support equipment,etc doesnt seem worth the investment just to win $3000 to $12,000 dollars and Wally if your ever lucky enough to win the Big Show and still be treated worse than a local bracket racer at your local track.....just my 2cents.
