Old 12-27-2010, 09:22 AM   #1
428tom
Default best rocker arm for stock
looking for any advise on the best roller rocker arm for stock class?
428tom is offline   Reply With Quote
Old 12-27-2010, 09:28 AM   #2
Dgal
Default Re: best rocker arm for stock
What is the application? If you are talking NHRA and the car didn't come with a roller rocker then you cannot use one. For example, and LT1 has stamped and you have to stay with stamped. IHRA allows roller replacements, I believe.
You need to be more specific.
Dgal is offline   Reply With Quote
Old 12-27-2010, 10:17 AM   #3
428tom
its on a ihra cratemotor small block ford.
Old 12-27-2010, 07:39 PM   #4
Dgal
That helps a lot, but unfortunately I cannot help you on a Ford application. I am sure someone may chime in soon.
Don
Old 12-27-2010, 08:10 PM   #5
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Thumbs up Re: best rocker arm for stock
For small block Ford I would go with Scorpion... Their top notch! for a 2nd choice I would go with Harland Sharp....they pay.
Old 12-29-2010, 03:21 PM   #6
CrateCamaro
CrateCamaro's Avatar
Liked 19 Times in 7 Posts
Dude I hope the means your kidding. HAHAHA. I wouldnt put scorpions on my lawn tractor. Ive seen them break in half. But im sure they would work on a bone stock motor with little valve spring pressure. Crane golds are the way to go if you want an aluminum body rocker...i have never had any trouble with them from my stocker to my mid 9 second street car. They take a beating and will handle loads of valve spring pressure and rpm. Comp Cams or Crower make a good steel body roller rocker as well. As for an NHRA approved rocker id have to say Crane Nitro "look alike" rockers are pretty tough. My buddy runs them on his DIRT car and when hes done with them he gives them to me and they show little to no wear after a tonne of laps around the oval.
My 2 cents
Tony Valerio 1968 Camaro
1700 IHRA H/CM
1701 NHRA SS/?A
Old 12-30-2010, 02:14 PM   #7
Phil Veldheer Racing
Liked 26 Times in 8 Posts
I've been using Harland Sharp on my IHRA stockers and my bracket cars for over 20 years. Harland Sharp just celebrated 50 years in business. I've NEVER had a problem and the family that owns and runs Harland Sharp are "car" people.
I am building another small block Chevy for one of my bracket cars that I also plan on running 200 mph at Bonneville and they build an AWESOME shaft rocker system for just about any head made.
At the 2010 PRI SHOW and the 2010 IMIS-Indy show they had a BUNCH of new rocker products, all made in OHIO. USA!!!!
I think they make the BEST available.
Phil
PHIL VELDHEER 3455 STK
IHRA WORLD Record Holder
2007-08-09-10-11-12-13-14-15-16
Phil Veldheer Racing is offline   Reply With Quote
