Old 12-27-2010, 11:21 PM   #31
FED 387
Liked 333 Times in 180 Posts
Default Re: 1970-1972 Chevelle frame...what will get me bounced?
Edelbrock & hotchkiss perf supposedly made/make some triangular stiffening plates that helped stiffen the frames on 454/455 engined cars---Supposedly all 454/455 used the A body convertible boxed frames whereas a sedan or 2dr ht used the standard C or non boxed frames
Old 12-27-2010, 11:45 PM   #32
Philip Saran
Liked 14 Times in 11 Posts
<So to those out there contemplating owning or driving a class car, I strongly suggest becoming a member, knowing the rulebook, subscribing to Nitro Joes Stats and going to your local class race and talking to the participants. >
The last ND I received before the holidays had an ad in it for the printed rule
book for $7.00 + handling charge if you called in the order. If you do it on
line then it is $10.00 + handling charge.
Phil Saran
Parker, Colorado
Philip Saran is offline   Reply With Quote
Old 12-28-2010, 10:16 PM   #33
bigshow2966
Liked 181 Times in 56 Posts
Talking Re: 1970-1972 Chevelle frame...what will get me bounced?
Originally Posted by Tom keedle View Post
is that the same ones that tie the upper and lower control arm mounts together?
that was a factory deal for ALL A bodys.
must be a reason for 'em cuz just about every chevelle/montecarlo/elcamino i've ever owned (a bunch) had 'em..
These were a single strut that went from the front lower control arm bolt to the frame. My buddy's '70 Stage 1 car had them, my small block Skylark did not.
I do not recall seeing anything that tied the top and bottom mounts though. I have not been under my Buick for a while though.
bigshow2966 is offline   Reply With Quote
Old 12-29-2010, 07:54 AM   #34
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
This is what the GM "A" body rear upper, and lower ca braces look like.....
http://www.musclecarmetal.com/catalo...er.asp?id=1552
They did not come on all "A" body cars, just the 4-speed, or big block, or cars with the "hi- performance suspension option......
Old 12-29-2010, 08:18 AM   #35
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
yep, that's the ones BUT my wifes old 68 300 chevelle had 'em...but you're correct, not ALL A bodies had 'em.
seldom seen them on 64-67's.
was there a TSB for them somewhere back then?
i dunno.
heard it was a retrofit kinda deal for some issue back then and it just went into assembly line cars...
60K 6 cyl/3speed...bought it from the original owner..
