Old 12-14-2010, 08:20 PM   #11
Mark Markow
Mark Markow's Avatar
Liked 9 Times in 3 Posts
Default Re: Best brake system to hold car on the line?
Originally Posted by art leong View Post
The SRT4 brakes are to big. I run the ACR stuff. But all Neons came with power brakes.
And I took off the power booster, but kept the stock mastercylinder. It stops fine at the end of the track but doesn't like to stop at slow speeds or hold the car against the converter.
I have new rotors and the organic pads.
art if your still using the master from the power brake set-up , i'm guessing the pedal is rock hard. it has to large a bore for manual brakes. when running manual brakes you need to go to a smaller bore, and modify the pedal ratio.
i would get a brake pressure guage, and see how much you get at the calipers. usually 900 to a 1000 max should do. i'll bet now your in about the 400 range? if you want send me a pm with some info on the calipers ,master cyl.bore size ,and current pedal ratio, and i'll try to get you sorted out.
Mark Markow
171 ss/tb
Mark Markow is offline   Reply With Quote
Old 12-14-2010, 11:05 PM   #12
art leong
Thanks Mark. I'll get that info together and send it to you
Art Leong 2095 SS
Old 12-14-2010, 11:08 PM   #13
art leong
Originally Posted by Myron Piatek View Post
Holeshot Wheels can probably make 15" wheels for your car, but then there is the matter of finding a short enough tire.
Thanks Myron. The 15" wheels are all over the place. But the shortest tire for them is 22"
Art Leong 2095 SS
Old 12-14-2010, 11:11 PM   #14
art leong
Art, what 14" slick are you looking for? Shorter than these even?
http://www.summitracing.com/parts/MTT-3020/
Thanks Jim those tires are 26" tall I need 20" tall M/T doesn't make the 14 X 8 X 20 anymore
Art Leong 2095 SS
Old 12-30-2010, 12:38 PM   #15
art leong
PM sent
Art Leong 2095 SS
Old 01-02-2011, 05:34 PM   #16
art leong
If I leave the same master cylinder. (it has a small bore) but increase the ratio. Will the car hold better?
I have very little pedal now, but it is rock hard. Car stops good at the finish, but terrible driving around the pits. Or coming up against the converter.
Art Leong 2095 SS
