Old 12-31-2010, 11:32 AM   #1
west coast
Liked 230 Times in 75 Posts
Default altenator pulley ratio to crank
I am in process of buying a new altenator and I am wonder what kind of ratio to use will have to buy a new crank pulley or make one. Only turning the motor 7000 rpm.
west coast is offline   Reply With Quote
Old 12-31-2010, 09:47 PM   #2
Dragsinger
Liked 99 Times in 60 Posts
Default Re: altenator pulley ratio to crank
A general guide line for full alternator output is to overdrive the alternator 30% - 50%
Example; a 5" crank pulley combined with a 3" alternator pulley = 40% overdrive. In this example, 1500 engine RPM will equal about 2100 alternator RPM
If the alternator is of the proper amperage output for your load the above example would have full battery voltage to everything with an engine speed of 1600 - 1800 RPM
This type setup will allow you to race all day without battery charging.
Larry Woodfin 471W
Old 12-31-2010, 11:20 PM   #3
Ed Wright
Ed Wright's Avatar
I just bought a low-mount alternator mount & pulleys from Jegs, and a pully set, meant for street rods. Has worked very well.
Ed Wright 4156 SS/JA
Old 01-01-2011, 11:29 AM   #4
Tom Goldman
Tom Goldman's Avatar
Liked 886 Times in 238 Posts
East Coast Auto Electric recomends a 2 to 1 ratio .
Most pulley kits made specificaly for drag racing are around this ratio.
I have run higher ratios in the past with no problems.
Old 01-01-2011, 02:07 PM   #5
Robert Simpson
Liked 20 Times in 12 Posts
Does anyone run a cog belt set up for a low mount sbc 69 camaro? Just curious...Thanks
Robert Simpson is offline   Reply With Quote
Old 01-01-2011, 06:52 PM   #6
Tom Goldman
I run a low mount cog on my BBC.
Check out Jones Racing Products in Ottsville ,PA.
They have a huge selection of cog drive parts..
Almost every circle track racer runs their stuff.
Tom
Old 01-02-2011, 09:38 AM   #7
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
here's something else to think about,
http://www.decouplerpulley.com/
i see potential...
Old 01-02-2011, 12:23 PM   #8
Tom Goldman
I tried one on my car when I had a micro v belt system on the car.
Two of them failed ,altho they were OEM units. ... locked up the overunning clutch.
may have been the rpm range , as I was running a small engine at the time and hitting about 8400 in the traps.
The most common application of these pulleys is on diesels ,to help minimize belt screech at shut down. ...They also cut down on belt whip when a automatic tensioner is employed .
Old 01-02-2011, 12:33 PM   #9
rod
Liked 20 Times in 15 Posts
try to limit the alt. rpm's to less than 20K. and then only for a very short period of time.
let's say U used a 6" crank pulley and a 3" alt. pulley. that would put the alt. turning 14K with the engine at 7K. the engine would only be at 7K at the top of some gears and for a short period of time.
now if U used a 6" and a 2" the alt would go 21K. way to much.
if you have no choice, then 1. make sure you use an alt. than can be easily [meaning not some special alt. which has to be ordered and takes three weeks to show up] and cheaply replaced or 2. have all the windings epoxy coated to keep it from flying apart.
in my case on my 265 i used a nippo denso alt from a 3 cyl chevy something. i used an old smog pump pulley [5" dia] drilled for the chevy three bolt dampner pattern and the original 2 3/4" alt pulley. that runs the alt at just a tad less than 2 to 1. my 265 hit 7K twice. and again only for a very short time.
be careful of some low mount kits on camaro's. the alt. pulley runs into the steering box. i spent 3 ours reconfiguring a friends. ugh.
rod in AZ
rod is offline   Reply With Quote
Old 01-02-2011, 08:50 PM   #10
Wade_Owens
Wade_Owens's Avatar
Liked 3 Times in 1 Post
x2, I have an east coast alt. also. 3" crank, 5" alt. no issues at all.
Wade O
