i have some questions on building a modified stock motor. i am looking at a b or c class and i am not clear on carburetor or a few other items. i also don't understand the cylinder head rule. pistons are another question. will somebody give me a little clarity on building a modified stock engine thank you.
Liked 9 Times in 3 Posts
750 cfm carb you can check the list for legal carbs . heads and block need an o.e. casting number. aluminum in b , iron in c. if it's a chevy combo . most in b use either a 15 or 18 degree gm, but the sb2.2 head is also legal. c guys use the iron vortec heads most often.must be an inline valve head only. as far as pistons, pretty much anything goes.
Mark Markow 171 ss/tb |
thanks mark----I feel like you need a lawyer to understand the NHRA rule book ----mistakes are expensive
Liked 880 Times in 311 Posts
Legal carbs & Bore size by NHRA:
CLASSES 750 CFM SS/BS, SS/CS, SS/DS,SS/TB, SS/TC, SS/TD, C/ED, ASR, A/SR, B/SR, C/SR, B/EA, C/EA. D/EA, E/SM, G/SM. CARB # PRI TB SEC TB PRI VEN SEC VEN 3310 1.687 1.687 1.402 1.463 4779 1.687 1.687 1.402 1.402 6109 1.687 1.687 1.402 1.402 6709 1.500 1.750 1.276 1.588 8156 1.687 1.687 1.402 1.402 9379 1.687 1.687 1.402 1.402 9645 1.687 1.687 1.402 1.402
Adger Smith (Former SS) Last edited by Adger Smith; 01-03-2011 at 12:30 AM. Reason: sp |
#5 | |
Liked 805 Times in 341 Posts
Bill |
most use the 4779 holley but barry grant makes a demon that is also legal. i'm using one. it works well out of the box. it's good place to start without having to send your holley out to someone for mods.
