Old 01-02-2011, 11:04 PM   #11
west coast
Liked 227 Times in 74 Posts
Default Re: altenator pulley ratio to crank
Wade are your pulley numbers backwards or is it just me. I have found pulleys for my crank with ratio of 2.26 and 2.10 for my altenator pulley size. Thanks guy's for the helpjust need to make brackets now.
west coast is offline   Reply With Quote
Old 01-02-2011, 11:08 PM   #12
nwebber
Liked 39 Times in 5 Posts
Is there any benefit to underdriving the alternator?
Norm Webber
nwebber is offline   Reply With Quote
Old 01-03-2011, 01:19 AM   #13
Tom Goldman
Tom Goldman's Avatar
Liked 886 Times in 238 Posts
Wades numbers are right for a Stocker that needs no real alternator output.
carburated Stockers run faster with a fully charged battery and an alternator that is really just along for the ride.
Old 01-03-2011, 04:30 AM   #14
GTX JOHN
I agree with Tom and Wade.....That how we run all our stockers (Although not the truck we use to tow them Home).
Old 01-03-2011, 05:47 AM   #15
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
I tried one on my car when I had a micro v belt system on the car.
Two of them failed ,altho they were OEM units. ... locked up the overunning clutch.
may have been the rpm range , as I was running a small engine at the time and hitting about 8400 in the traps.
The most common application of these pulleys is on diesels ,to help minimize belt screech at shut down. ...They also cut down on belt whip when a automatic tensioner is employed .
i was kinda thinking that might help on gear changes...just a thought.
Old 01-03-2011, 10:33 PM   #16
Bob Bender
Bob Bender's Avatar
Liked 460 Times in 91 Posts
Originally Posted by Wade_Owens View Post
x2, I have an east coast alt. also. 3" crank, 5" alt. no issues at all.
Wade O
Me too.......................
Bob Bender 144 O/SA
Old 01-04-2011, 11:52 AM   #17
west coast
I should have mention this is a stocker. Wade and Bob are you guys just running off the battery and not running any electricity to the altenator?
Old 01-04-2011, 05:12 PM   #18
GTX JOHN
We use Denso Alt. and still have 13.8 to 14.2 volts above 2,500 with above ratio.....I like all the voltage I can get with MSD. We are seldom below that RPM even in Pits.
John Irving
Old 01-04-2011, 05:17 PM   #19
Wade_Owens
Wade_Owens's Avatar
Liked 3 Times in 1 Post
With my ICE Ignition, he likes to see over 14v. By about 3000-3500 rpm's, I have 14.4
I did have a racepak on for awhile, after peaking at 14.4, it stayed there for the duration of the run.
We do have to have a working alternator, hooked up and charging as per rules.
Wade O
Old 01-05-2011, 02:40 AM   #20
Bob Bender
Bob Bender's Avatar
My alt. turns on at approximately 3000 to 3200 rpms and puts out 14.2 volts.
Bob Bender 144 O/SA
