Old 01-05-2011, 07:47 PM   #1
TinSoldier 3215
Liked 6 Times in 5 Posts
Default trans
jerico, lenco, liberty what's your all choice? for a bracket stick car! I trust you stock and superstock guy's!!! Thanks.
TinSoldier 3215 is offline   Reply With Quote
Old 01-05-2011, 09:37 PM   #2
james schaechter
Thumbs up Re: trans
Probably more info about the car would help. Hp, weight and your budget all play in here.
In general, it is hard to beat a Jerico. If you can, buy a new one.
If you are looking at a used one, make sure to research it before you buy one.
The case number and a call to Jerico can help.
James Schaechter 3163 STK
Old 01-05-2011, 09:44 PM   #3
TinSoldier 3215
Default Re: trans
Jim, The car weight is 2200 with a small block that runs 8.90 and I want to do it RIGHT the first time!
Old 01-05-2011, 10:21 PM   #4
james schaechter
Exclamation Re: trans
Sounds like fun. If there are no rules involved, I would choose a Liberty for it. My opinion for what it is worth. Again, there are deals occassionally used, but if you are looking research before you buy. New is best if you can do it.
Old 01-05-2011, 10:45 PM   #5
Stewart Way
Liked 70 Times in 22 Posts
Default Re: trans
I had a 2240 lb Tbird with a lenco that went 8.80. I chose Lenco because I figured I would run a single disc iron clutch with a non-adjustable plate. The Lenco, with the internal clutch packs, lightened the hit on the tires between the gears. Used a delay box and an air cyl on the clutch arm with a hyd throw out bearing. Plus the lenco is just a cool look in the car.
I am going to run a Gforce in my SS car but I would still go Lenco in a light bracket car.
Stewart Way 2424 SS
Old 01-06-2011, 10:55 AM   #6
TinSoldier 3215
Default Re: trans
James, and Stewart, The car is going to be set up for Umtr stick racing. so with that being said,do you still think a lenco or liberty? Thanks
