#11 |
Liked 87 Times in 9 Posts
As said in an earlier post check the back of the crank. I have had this issue with two different cast cranks. The cranks werent machined deep enough. Inspect it with a light and see if there are any contact points.Something I also do is drill a small hole through the bearing into the main bearing oil hole to provide positive oiling to the thrust. Good luck.
Ken Etter 7375 STK/5 SS |
#12 | |
Liked 12 Times in 5 Posts
Thanks for the input. Will check the crank again. Mike |
#13 |
#14 | |
The converter is due for a freshening up and we were planning on sending it out anyways. Thanks for the response. Mike |
#15 | |
Mike |
#16 |
#17 |
#18 | |
Mike |
#19 |
Liked 19 Times in 7 Posts
There is a lot of info on the net. Do a search for thrust bearing problems. and look for the AERA paper on diagnosis and symptoms. most likely restricted coolers or cooler lines cause the torque converter to be pushed forward causing thrust problems. check your cooler line pressure.
#20 |
I had problem with imput shaft on my 904 being significantly Bent.....Also I would dial indicate end of crank flange.....I have seen Cast small block cranks becoming seriously bent.
