Old 01-17-2011, 04:06 PM   #1
StockerRook
Default Front Tire Size
Is a 26" tall front tire going to be big enough for a F-Body Lt1 Stocker. A buddies dad bought some and needs a 24". I was wondering if you guys are running a 27" or 28" or if these 26" will work fine for me?
Thanks for any help
Chris
StockerRook is offline   Reply With Quote
Old 01-17-2011, 04:17 PM   #2
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Default Re: Front Tire Size
Most of the F bodies I build have 26" tires on them.
I would have liked a taller tire on the one I drove to slow down my reaction times,but tire clearance is a little tight.
Even with the 26" tire you will have to trim out the top of the inner fender, or the track crew will be following you after a wheelstand to pick up whats left of the liner.
I have put 27" tires on one car I did, but we did have to raise the front end a little to keep them from hitting even when making a slight turn.
Old 01-17-2011, 04:31 PM   #3
StockerRook
Thanks Tom, I appreciate the help.
Old 01-17-2011, 05:15 PM   #4
Dgal
You might ask around. We were running a 28" for a while and it was a little tight, but I think many are running one now. This is on a '98 Firebird. We are running a 27" now and plenty of room with the factory fender liners.
Don
Dgal is offline   Reply With Quote
Old 01-17-2011, 06:07 PM   #5
Ed Wright
Ed Wright's Avatar
27" tires rub on mine when turning very sharp. Lower cars will rub sooner.
Ed Wright 4156 SS/JA
Old 01-17-2011, 06:12 PM   #6
Tom Goldman
I will agree with Don on this . ask around.
Front springs, and different wheel offsets and especially tire manufacturers will make a difference. Goodyears
28" front has a bigger rollout than Hoosier or M/T. ....but the Hoosier 27" is bigger than the Goodyear .
The 26" tires seem to be closer among the manufacturers.
Old 01-17-2011, 06:36 PM   #7
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
When I put together my LT-1 Firebird....I replaced the front fender liners as the one on the car were all scraped up. It never occured to me why they were all torn up!
I had 26 or 27" front tires and single adjustable front shocks. They were set loose.....and the nose was pretty low
Tom Goldman mentioned to me before I made my first run that the tires would tear up the plastic liners........They did on the very first run and the car was so slow it could barely get out of it's own way! When I got on the brakes the nose dropped and the tires ripped the liners up.......Wasted a lot of time and a few dollars learning that one........
I raised my car a good deal by raisng the spring seats and still had the issue of the nose tripping the beams twice.....
I highly recommend either a double adjustable front shock or a down travel limiter device.....
Rich Biebel
S/C 1479
Stock 147R
Old 01-17-2011, 07:53 PM   #8
Ed Wright
Ed Wright's Avatar
Rich, what kind of down travel limiter?
Old 01-17-2011, 08:12 PM   #9
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Originally Posted by Dgal View Post
27" and plenty of room with the factory fender liners.
agree, 27" tires here
but come down hard from a wheels up launch and you'll leave the inner liners on the track. Done that twice now, new liners will have the tops cut out.
Old 01-17-2011, 08:18 PM   #10
Rich Biebel
Ed Wright.......... I never got around to making one, sold the car. I did have some ideas though. I would have tried the 90/10 style shocks or Afco's first.....
A heavy rubber snubber would be my first choice but there was not much area under one of those cars for one like found on an early F body
I lost a round at a Lucas series race from a bogus time slip due to that front end deal. Might have lost anyway but I didn't think so at the time and especially from the numbers that were on the slip.....
Also had it happen at a weekly bracket race........that nose came down way too far and fast with the shocks set loose.....The car loved it back at the starting line and so did I.......but down at the finishline it was another story...
Rich Biebel
S/C 1479
Stock 147R
