Old 01-27-2011, 05:34 PM   #1
Philip Saran
Liked 14 Times in 11 Posts
Default Tire pressure gage??
I need to purchase a decent tire pressure gage, something in the
30 to 60 lb range. Main purpose will be for tires and radial slicks.
Anybody have a favorite brand that works correctly?
Phil Saran
Parker, Colorado
Philip Saran is offline   Reply With Quote
Old 01-27-2011, 06:26 PM   #2
FINESPLINE
FINESPLINE's Avatar
Default Re: Tire pressure gage??
Hi Phil, I have had a moroso tire gauge for about 6 years with absolutely no problems. I received it as a birthday gift and have used it on my everyday cars. It has a built in bleed to make to make fine adjustments. Moroso now makes a few different ones and vary from about 38.00 to 145.00. Go to their site and see what best fits your need which probably be a 0-60 lb. Be sure to get the rubber protector for an extra 5.00 worth it if you drop it.----------John
FINESPLINE is offline   Reply With Quote
Old 01-27-2011, 06:49 PM   #3
Dragsinger
Liked 99 Times in 60 Posts
I have this gauge, works fine.
http://www.intercomp-racing.com/Prod...RESSURE_GAUGE_
Larry Woodfin 471W
Old 01-27-2011, 06:51 PM   #4
Dragsinger
anywho, the above link may not work. Go the the Intercomp Gauges web site and look them over. You will see a wide range of options.
Larry Woodfin 471W
Old 01-27-2011, 07:52 PM   #5
Bob Don
Bob Don's Avatar
Liked 903 Times in 192 Posts
Moroso #89560
Bob Don 128 SS
Old 01-27-2011, 08:01 PM   #6
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
This is all I've ever used for 20 years
I also don't check/adjust tire pressure between rounds and my cars are deadly consistent vary thousands in 60 feet from pass to pass.
I've also been running radial slicks since 2000.
Old 01-27-2011, 09:35 PM   #7
Shawn Blair
Shawn Blair's Avatar
Thumbs up Re: Tire pressure gage??
Moroso 0-60 psi with rubber protector works great for me!
Shawn Blair 6383 SS 634 STK
Shawn Blair is offline   Reply With Quote
Old 01-27-2011, 10:12 PM   #8
Chris DeGidio
Chris DeGidio's Avatar
Liked 2 Times in 2 Posts
Moroso here also.
Nautilus Racing
Chris DeGidio is offline   Reply With Quote
