Old 02-02-2011, 06:35 PM   #11
Jeff Lee
Jeff Lee's Avatar
Default Re: 396 2bl combo
Of course on a 2bbl it is easier to activate the tilting mechanism with the throttle linkage. Don't forget to adjust the fuel mixture for WOT, not pit cruising!
Jeff Lee 7494 D/S '70 AMX
Old 02-03-2011, 07:36 AM   #12
FrankChastain
Location: Trussville, Alabama-Originally from Vidalia,GA
Mark, did you happen to try the old flat washer trick between the 2 bbl and the intake. Bet Jimmy Parker can relate to those days....Not meaning he did it, but that he saw it.....Frank
In 1972, I was testing our 61 Chevy, 2 bbl, PG, SS/X car at Ct Dragway.
It was running around the new minimum (14.80's ) I stuck on the WCFB from Joe S's 61 Vette, and picked up about a second . No one on hand ,including several S/S racers, even noticed!
Goes to show , some think all slow combos are bogus!
FrankChastain is offline   Reply With Quote
Old 02-03-2011, 11:07 AM   #13
Doug Domm
Liked 84 Times in 21 Posts
I have the intake, carb, air cleaner and heads if anyone is interested.
Doug Domm is offline   Reply With Quote
Old 02-03-2011, 12:46 PM   #14
No, not on that one, seeing it was a PG car.
I DO know ,you can remove three little parts from a 4GC carb and pick it up over a tenth..
or so I'm told. LOL
Old 02-03-2011, 03:10 PM   #15
Chad Rhodes
Originally Posted by Jack McCarthy View Post
i have that 2bbl 396 intake !
call if ya need one !
jack
502-558-3450
Hell Jack, I've got the crank out of one. Was never bored for a pilot bushing. Its also 5lbs lighter than any other 396/427 crank we have. Unfortunately it died an untimely death at the hands of a spun rod bearing
Chad Rhodes 2113 I/SA
Old 02-03-2011, 03:37 PM   #16
Greg Reimer 7376
Liked 719 Times in 220 Posts
Cool Re: 396 2bl combo
Seems to me the bottom half( short block,cam, pistons, etc.) on that engine were the same as the 325 horse. the heads were one-off, about equivalent to a 71 402 head,but with a different part number, but that crank you mentioned is a cast crank. Almost all the 68-9-70-71 396/402 standard production units were cast. ('<').
Old 02-03-2011, 06:18 PM   #17
Chad Rhodes
yes it is a cast crank. Dad got the whole motor out of a wagon wayyyy back when. Only one we have ever seen not drilled for a pilot bushing, or that light. It was a different piece for sure
Old 02-03-2011, 10:07 PM   #18
gsa612
gsa612's Avatar
Liked 280 Times in 139 Posts
I don't know if this is an urban legend, about 20 years ago a guy told me to find a 335 hp. 427 crank same stroke as a 396 (cast). I believe it was 69 only no pilot bushing and was lighter than 325 396, cannot find the casting no. gsa612
Old 02-04-2011, 11:10 AM   #19
Chad Rhodes
that's the crank but it was a 2bbl 396 out of a wagon (not 100% sure on the hp), may have been the same in a 427/335
Old 02-04-2011, 11:21 AM   #20
danny waters sr
danny waters sr's Avatar
Thumbs up Re: 396 2bl combo
69 Full size and wagons only @ 265/265. Do not see it in any other year in my books
